• 29.11.2026, 05:23
dxb750
2 tubemeter USB fill level sensor >>> Problem!!?
samedi 5 janvier 2013, 19:02
I have two tubemeter USB and I connect it like this :
*There Internal USB Expansion between the tubemeter and the motherboard.. http://www.amazon.com/gp/product/B0031ESKJA
Often all the tubemeters do not work, and sometimes only one tubemeter working with aquasuite !
Is it one previously faced the same problem??
Thanks,
Ce message a été modifié 1 fois. Dernière modification effectuée par "dxb750" (5 janvier 2013, 19:29)
dxb750
dimanche 6 janvier 2013, 19:18
I tried to connect it directly to the board, but the same problem!
:wacko:
LarryWill729
lundi 7 janvier 2013, 02:02
I think the problem is that the tubemeters might not have a changeable address like the PA2 and mps.
One other user has two tubemeters installed and if I remember correctly he connected one via USB and the other is connected to the low speed Aquabus connector. This requires a four wire connector and there is not quite enough room to use a five pin USB connector. So use a four wire Aquabus cable and you should be fine.
AMD FX-8150 OctoCore O.C. 18% to 4.2 GHz on ASUS M5A99X EVO with 16 GB Corsair Dominator W. C. RAM, 2 nVIDIA Geforce 560TI W.C. in SLI, six Western Digital drives for a total of 4.07 TBytes, AquaComputer Aquero 5 Pro, AquaComputer D5 pump, Multiswitch USB, tubemeter and Kyros CPU block. Two coolant loops,CPU & SLI, MB, RAM and AQ5, with two flow meters. Running Windows 7 Professional 64, and using Open Hardware Monitor v0.5.1Beta Aquasuite B16 hardware temps.
dxb750
mardi 8 janvier 2013, 11:57
Thank U very much Larry :)
tpb211
vendredi 18 janvier 2013, 07:35
Was your probles resolved? I too am running the same tube meter and running into all kinds of difficulties. sometimes the LED blinks on it, sometimes it does not, always reports 90% lvl have never seen it budge by even a single percentage. I am wondering if my unit is buggered and not relaiable. Looking for more advice specifidcally on when the led on the tube meter should be flashing and for how long.
Discussions similaires
