• 10.10.2026, 15:13
mrbean
Shoggy: Help needed to purchase MSi Lightning 680 GTX waterblock and twin connect kit
dimanche 20 janvier 2013, 12:10
Hello Shoggy,
Ok, as I mentioned a while back, I have one GTX 680 Lightning block, and now I got the 2nd card for some SLI action.
I am ready to order the new waterblock from you, but I also need a twin connect adapter, like this one : http://shop.aquacomputer.de/product_info…roducts_id=2495
Will this also work on the MSI 680 Lightning blocks? I will use the Asus Rampage IV Gene motherboard, micro-ATX form factor....
I will appreciate your quick response, then I can order this asap, thanx Shoggy!
Kind regards,
Phillip aka mrbean
Ce message a été modifié 4 fois. Dernière modification effectuée par "mrbean" (21 janvier 2013, 22:13)
mrbean
lundi 21 janvier 2013, 11:07
Bump.... :)
Jakusonfire
mercredi 23 janvier 2013, 15:42
It says on the 680 Lightning page
The terminal can be replaced with twinConnect kits for SLI configurations (art. no. 23497, 23501 or 23532, not included in delivery)
Which is the type you linked to.
mrbean
lundi 28 janvier 2013, 10:24
Thanx Mate, yeah, I discovered it will work.
Appreciative of your feed back though :)
