• 02.10.2026, 02:15
SverreMunthe
Maximum temps on amps
mardi 12 février 2013, 17:12
What is the max temp for the Aquaero 5xt CPU and fan amps. Same question for Poweradjust II. Trying to set warning and alarm on the Aquaero CPU
Namron
mardi 12 février 2013, 23:04
On my XT they ramp up the fans to 100% when they reach 95°c, That was using the standard fitted heatsink that came with my XT well over 12 months ago), But with a water block they never get close to this :)..
N.
_KaszpiR_
samedi 6 avril 2013, 13:17
AFAIR when amps hit 95 C then the electronics forces them not to adjust the voltage, so they will cool down.
After dropping below 70 C they start to control voltage/current again, so they start to heat up.
So in the worst case scenario you hit 95C and then fans start to spin with full speed, because aquaero tries to not to burn the amps.
http://martinsliquidlab.org/2011/12/20/a…ew-guide-wip/9/ here is a good description and testing.
tpb211
samedi 20 avril 2013, 20:12
Not sure on the AQ5, but the PA2 Ultra's with latest firmware begin cycling at 80c
