• 18.11.2026, 04:01
Psychor
MPS 400 reporting 3.86 gal/hour?
lundi 11 mars 2013, 15:57
I have an MPS 400 connected to a loop comprising a pump and filter. I use this for cleaning loops. The MPS 400 is rated for 80 - 400 liters per hour / 21 - 106 US liquid gallons per hour.
So why is it reporting 3.86 gal/hour? 8| Shouldn't it report 0 or something since it's below the minimum?
Psychor
lundi 11 mars 2013, 16:12
While fooling around with the settings I selected "13/10 mm" (which by default was BLANK) and then hit "Import Calibration Dada." My flow shot up from 3.xx gal/h to 82 gal/h.
The manual says "13/10 mm" is the "type of fittings." Is that the ID of the fitting? I'm using 1/2" barb fittings.
Psychor a envoyé l’image suivante :
Ce message a été modifié 2 fois. Dernière modification effectuée par "Psychor" (11 mars 2013, 16:16)
Nihil Simile
Fitting size
lundi 11 mars 2013, 22:41
13mm is equal to 1/2 inch, and 10mm is equal to 3/8 inch.
Psychor
RE: Fitting size
lundi 12 août 2013, 20:45
Thanks.
So I reset my MPS 400 today and now the drop down menus for "Load flow calibration curve" are completely empty. Any idea what's going on?
As a result my flow is showing ~6 gal/h which is incorrect. Prior to resetting my MPS 400 it was 80+ gal/h.
