• 27.11.2026, 19:07
Wyza
Aquaero prevents windows from booting
samedi 23 mars 2013, 02:44
So I've been running the Aquaero 5 LT for a couple of months now. I love it. However I've had 1 annoying thing which is if the USB connection between the Aquaero 5 is plugged into the motherboard during POST / windows boot, it will go to a blank screen with a flashing cursor. If I unplug it, reboot, wait for windows to start up, plug it back in, all is well. Initially i just assumed something was awry with my windows install (it was over 2 years old) and recently had the chance to do a fresh install. I have also left it plugged in and gone to the BIOS to make sure that it isn't trying to boot from it (don't know why it would but...). With no luck. I'm running an ASUS Sabertooth 990FX as the mobo.
Thoughts?
Jeremy
samedi 23 mars 2013, 05:29
Have you checked for a motherboard BIOS update from ASUS?
Wyza
dimanche 24 mars 2013, 01:34
Not yet, I don't like updating BIOS firmware unless I have to, so I figured I'd ask if anyone had seen the problem before.
Jeremy
dimanche 24 mars 2013, 02:20
My motherboard had an issue where it would boot-loop the POST constantly if I started it with an external hard drive connected to USB. After I updated the BIOS firmware, the issue went away. That's why I suggested checking for an update. It's a pretty safe and easy process on most motherboards made in the last 5 years. WAY easier than it used to be.
marchitect
mercredi 27 mars 2013, 02:19
For a small fee, you can get a new bios chip from ASUS with the latest BIOS version on it. I just did this and it worked out fine.
Wyza
jeudi 28 mars 2013, 01:34
So as suggested I updated to the latest firmware for the bios. It was surprisingly smooth. Sadly the problem still persists.
jeudi 28 mars 2013, 07:31
have you updated your aquaero 5 to the latest version?
Grasshopper
dimanche 5 mai 2013, 01:08
hi,
If you enter bios ( press delete during post) and check HDD boot priority, make sure your system drive(s) is the first choice, and then look at device boot order ( ie cdrom 1st HDD 2nd etc) As your problem appears to me to be your comp is attempting boot from the AQ
