• 22.11.2026, 23:29
Phatboy69
Fan animation custom control in Overview page
mercredi 27 mars 2013, 12:22
Hi AC team!
I have a question regarding getting the rotating fan animations to work on the overview page.
I've added more fan channels and the custom control for the rotating fan animation but i dont know which data source to bind it too, to get it to work? Ive tried all the individual fan elements and values and the only one that it will accept as a data source is the 1st menu level item (fan channel) under the fans but that doesnt make it rotate?!??!
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
mercredi 27 mars 2013, 13:00
the fan in demo page rotate when a rpm is measured.
when you copy the fan animation icon you have to change the data source in the element. (not the source on right click). When you change the data source try to restart the aquasuite.
It is not necessary to change the xaml code.
Phatboy69
mercredi 27 mars 2013, 14:15
Thanks all sorted! ;)
