• 03.10.2026, 14:08
mirtzbass
multiswitch 1.41 problem
mercredi 17 avril 2013, 07:54
hi! i'm testing the aquaero 5 and the multiswitch 1.41. no problem with the first but aquasuite can't see the multiswitch. i have checked and the MS is seen by th pc as non specificated drive. my os is windows 8
thanks for help
mercredi 17 avril 2013, 08:24
the multiswitch is only supported by aquasuite 4.xx (USB), not aquasuite 2012.
When you connect the multiswit with aquabus you can control the outputs with the aquaero 5 and the aquasuite 2013.
mirtzbass
mercredi 17 avril 2013, 08:38
ok but i don't understand.......i have to see more menu under aquaero 5?? for example how can i controll the leds output of the multiswitch?? if you can post a pic it will help me
mercredi 17 avril 2013, 08:47
When you connect the multiswith with USB, you have to use the aquasuite 4.72 NOT aquasuite 2013.
mirtzbass
mercredi 17 avril 2013, 08:57
and this is ok! now i have linked the aquaero 5 with the multiswitch via aquabus........ok so is not clear how to control with aquasuite 2013!
mirtzbass
mercredi 17 avril 2013, 09:05
here is a pic of my aquasuite.........which submenus i have to use???
Ce message a été modifié 1 fois. Dernière modification effectuée par "mirtzbass" (17 avril 2013, 09:07)
mirtzbass
mercredi 17 avril 2013, 09:29
i have tried aquasuite 4.72 and multiswitch via usb and i can controll it. after that i have linked the multiswitch via aquabus (low port on the aquaero 5) and used aquasuite 2013 it's not clear how to use it. there are no menus for the MS.
also how can i see if the ms is linked to the aquaero 5??
Ce message a été modifié 1 fois. Dernière modification effectuée par "mirtzbass" (17 avril 2013, 09:32)
mercredi 17 avril 2013, 09:36
When the aquaero 5 detect the multiswitch via aquabus you have new outputs in the output tab from the aquaero.
The new outputs listed in the drop down menu with the aquaero relay. In thecontroller section you have more outputs in the dialog page.
mirtzbass
mercredi 17 avril 2013, 09:56
the drop menu is completely white but if i click on a point of it i can change output. now i try to use a led as test
Ce message a été modifié 1 fois. Dernière modification effectuée par "mirtzbass" (17 avril 2013, 10:08)
mirtzbass
mercredi 17 avril 2013, 10:23
ok nothing! the multiswitch as stopped to work also with usb :( unknown device. are there any drivers or firmware to try manualy???
edit: i don't know why but now it's ok from aquasuite 2013!!!! :D
last question: i have to link two d5 pump motor (version with usb and aquabus) how can i do??
edi again : the problem is returned.....seems that the controller have some problem
Ce message a été modifié 5 fois. Dernière modification effectuée par "mirtzbass" (17 avril 2013, 15:53)
