• 09.10.2026, 10:07
xvs87
2 x Aquaero 5 XT
mercredi 1 mai 2013, 03:13
Is it possible to run two Aquaero 5 xt's?
I have 2 x mcp35x2's so i was thinking that on each aquaero I could have (1 x mcp35x2, 1x Flowmeter, 2x 4-set of fans, 4 sensors).
This would allow each Aquaero to be responsible for its own water loop. Will this work?
Does Aquasuite have the ability to talk to 2 Aquaero's simulaneously or will I have to run one as a Slave, if so will I loose the PWM header for the pump.
Phatboy69
mercredi 1 mai 2013, 10:11
You can run both AQ 5 XT off seperate internal USB ports and have full functionality of all sensors and controllers and Aquasuite will treat them as independant controllers no problem!
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
xvs87
mercredi 1 mai 2013, 10:50
Awesome, does it have to be wired into the Mobo or can I use any usb port that is connected to the computer?
Phatboy69
jeudi 2 mai 2013, 11:44
Its designed for internal MB USB port headers but I guess you could use an adapter that would convert external USB to internal header if you dont have enough internal ports?
Something like this.. http://www.scorptec.com.au/computer/47189-c-rausb3002-in
Discussions similaires
