• 23.11.2026, 19:45
balizeiro
Aquaero 5 LT and profile load in Alarm Actions
vendredi 3 mai 2013, 20:05
I already saved several profiles (to .pro file), but I don't know how to associate them with profile 1, 2.... so that I can use them as actions for the alarm settings.
Can I specify profiles with Aquaero 5 LT, or not? If yes, how?
Thanks in advance
vendredi 3 mai 2013, 23:18
Profiles not available for aquaero 5 lt.
balizeiro
samedi 4 mai 2013, 01:06
So I can't change profiles in Alarm Actions?
Or is there any other way to set it?
Is it planned to be possible to set it in the future?
EDIT: Because what I need is to change the speed of my pump if the flow drops below a certain value
Ce message a été modifié 1 fois. Dernière modification effectuée par "balizeiro" (4 mai 2013, 14:55)
balizeiro
vendredi 10 mai 2013, 20:37
Anyone? ;(
Grasshopper
samedi 11 mai 2013, 01:30
With the AQ5 Pro in alarm actions page of aquasuite, I can add the action "load profile1", or load profile 2 etc
can you?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Grasshopper" (11 mai 2013, 01:49)
balizeiro
samedi 11 mai 2013, 21:12
I can load a profile as an action for an alarm, the problem is that I can't specify what's profile 1, 2....
Ce message a été modifié 1 fois. Dernière modification effectuée par "balizeiro" (12 mai 2013, 00:25)
arad85
mercredi 15 mai 2013, 10:00
Hello all, first post.
I have the same problem too (I'd like to set fans to 100% on an alarm) so would like to add it as a feature request for LT users....
Ce message a été modifié 1 fois. Dernière modification effectuée par "arad85" (15 mai 2013, 10:20)
Jeremy
vendredi 17 mai 2013, 15:42
This is interesting. I thought the LT was everything the XT was (identical control board), so why is this feature not available? Is it simply for product differentiation, or can we hope that the feature will be enabled at some point?
"Please note that at present not all functions are available for the aquaero 5 LT. If you want to use specific functions and you are not sure if they have been already integrated to the aquasuite 2012 software, please contact our support."
That's all the product description provides. Are there any other XT features that are not available on the LT?
Grasshopper
samedi 18 mai 2013, 00:26
AS2013 only works with 1 profile, if AS had tabbed profiles you would not need a switching mechanism to access other profiles.
Perhaps the limitation of the AS running real time.
balizeiro
samedi 18 mai 2013, 13:38
... you would not need a switching mechanism to access other profiles...
A button/tab/radio button/check box.... in the interface???
