• 07.10.2026, 16:04
917K
Kryographics for GTX 770?
vendredi 28 juin 2013, 18:56
can this GTX 780 waterblock be compatible with GTX 770 with reference desing, for example the EVGA 02G-P4-2774-KR?
I've done a rapid visual comparison between the PCB of the 780 and one of the 770 and i've not found significant differences apart the 8 RAM modules of the 770 instead the 12 of the 780.
@AC: If not did you have in program to make a kryographics wb also for the 770?
Thanks in advance for the answer.
Grasshopper
samedi 29 juin 2013, 03:19
look at the location of the blue / silver capacitors on the right side of the circuit boards...even the position of the memory on the boards is different. Does that answer you question about using 780 block on 770?
917K
samedi 29 juin 2013, 08:16
Unfortunately, you're right, I've didn't noticed it.
Thank you very much for the answer.
Still remains the second question for AC
