• 23.11.2026, 01:01
kazaflo
Little question for the 360 eco +
vendredi 5 juillet 2013, 15:16
I just buy the 360 eco+ and i have some question about the pipe and fittings.
For persons who have a aquaduct i have a pipe inside the box and i wanna know what is the appropriate fitting because i don't if it's 8/10 or 8/11 or etc ...
I need to know for this devise :
http://www.materiel.net/waterblock-pour-…ckel-79978.html
http://www.docmicro.com/pieces/news-EKWa…ETAL_10466.html
Need your help !
:D
(sorry for my english, it's a little bad ^^)
vendredi 5 juillet 2013, 15:32
P&C 8/6 is the AC standart
kazaflo
vendredi 5 juillet 2013, 15:45
Ac standart is 8/10 ?
vendredi 5 juillet 2013, 15:56
No 8/6mm P&C
Ce message a été modifié 1 fois. Dernière modification effectuée par "EnigmaG" (5 juillet 2013, 18:30)
Jeremy
vendredi 5 juillet 2013, 18:05
The fittings on the Eco units are G1/4. You can use whatever barbs and tubing you want with it AFAIK.
If you're talking about the tubing INSIDE the unit, I'm not sure those are user-serviceable.
kazaflo
lundi 8 juillet 2013, 10:40
Ok, thanks, i have my answer now. I just buy 2 G1/4 fitting. I will install this tonight. ^^
kazaflo
lundi 15 juillet 2013, 22:29
Hi, it's me again.
So, i have some problem with the installation of an 360 eco+.
I think all my connection are ok.
When i start my computer for that the water flows through the pipes. I heard the pump but no flow in the pipe and the fan in the aquaduct don't turn.
This is an image of the card (link with the cpu fan):
http://image.noelshack.com/fichiers/2013…0715-220847.jpg
I need help because i wil become crazy ^^
Jeremy
lundi 15 juillet 2013, 22:38
Did you set it up as the instructors say to?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Jeremy" (15 juillet 2013, 22:43)
kazaflo
lundi 15 juillet 2013, 22:42
Yes. I take a picture of my computer and the aquaduct.
http://www.noelshack.com/2013-29-1373920…0715-223839.jpg
Jeremy
lundi 15 juillet 2013, 22:44
How is your fan header configured in your BIOS? It'll need to be set up for voltage control instead of PWM control.
kazaflo
lundi 15 juillet 2013, 22:53
it's PWM control. What is the voltage for the fan ? And when i start my computer i have a bip from the aquaduct.
When i start my computer, i just have one bip but no pump and fan turning ...
Ce message a été modifié 2 fois. Dernière modification effectuée par "kazaflo" (15 juillet 2013, 23:30)
Discussions similaires
