• 21.11.2026, 11:55
pitahbread
Need assistance with High Flow Meter USB Setup.
dimanche 4 août 2013, 02:52
Hey guys, I've been attempting to setup my High Flow Meter USB with no success. I have it hooked up by USB at the moment but I cannot seem to get it to show up under the "sensors" tab under aquaero.
The flow rate and internal temperature sensor seem to be working in the second picture in the alarm configuration tab.
Thanks for all your help.
Ce message a été modifié 2 fois. Dernière modification effectuée par "pitahbread" (4 août 2013, 02:54)
Grasshopper
mercredi 7 août 2013, 10:59
think you will find it is the MPS
pitahbread
jeudi 8 août 2013, 01:49
Do you mean I have to switch the device to "Flow sensor mps flow" instead of the "Flow sensor high flow usb?"
pegleg
dimanche 11 août 2013, 22:56
i cant seem to get mine to show up either,that how it looks on mine to
pitahbread
dimanche 18 août 2013, 03:16
Hm I'm assuming you just left it alone?
pegleg
dimanche 18 août 2013, 15:30
no i want to fix it and for it to do what it should..lol
pitahbread
lundi 19 août 2013, 07:06
Fair enough. I'm going to reset the High Flow USB Meter back to factory defaults and wire it up again, I'll get back to you on how that works out.
pegleg
lundi 19 août 2013, 18:37
i have tried all that dont know what too do or why its not showing up as flow 11 just flow 1 flow 2 thats all thats shows up i had it working before i did my rebuild.
Could are aquaero5 be messed up?
Ce message a été modifié 1 fois. Dernière modification effectuée par "pegleg" (19 août 2013, 18:39)
pitahbread
lundi 19 août 2013, 21:22
No clue, mine doesn't even show up as Flow 1 or 2 =\.
pegleg
mercredi 21 août 2013, 01:49
i just did mine again. i don't know what is wrong with it either,I see the 1and 2 flow but no flow 11
pitahbread
jeudi 22 août 2013, 14:08
So I reset my High Flow Meter USB back to the factory default but nothing changed but I realized that I don't even have the option to set my flow sensors to the correct flow meter.
If you look at the options I have it only displays the older High Flow sensor(53068,) not the USB one which is manufacturers code 53129. This is also after selecting "Flow sensor high flow USB" in the configurations tab under MPS.
Are you having these issues as well?
Jakusonfire
vendredi 23 août 2013, 05:09
Those settings don't change anything anyway. They are just the default pulse count but the USB flow sensor does its own processing. changing the pulse count number does not do anything, it is only for the older sensors.
It sounds like fully resetting the Aquaero and reinstalling Aquasuite is all there is left to try. It seems like either the Aquaero or Aquasuite is confused because it should not show those extra flow sensors 4, 5 and 6 unless you have renamed them to that, or you have poweradjusts connected.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Jakusonfire" (23 août 2013, 05:14)
pegleg
vendredi 23 août 2013, 05:32
I had a power adjust 2 on mine but, i never got it to work so i just took it off.all i get is the flow 1&2 no 11
how do i do a hard reset on the aquaero 5?
pitahbread
dimanche 25 août 2013, 15:00
I do have 3 Power adjust 2s connected along side my Aquaero 5 Pro. Should I still fully reset my Aquaero and re install Aquasuite?
pegleg
lundi 26 août 2013, 17:26
i guess nobody can help us with problem and nobody can tell me how you do a hard reset on the aquaero 5 xt. theres noway to reset the aquaero 5 xt without the software like on my aquastream xt pump u take and put black piece they give u on the temp sensors and it resets it.
Namron
lundi 26 août 2013, 21:15
Have a look HERE Scroll to the end & there you will find a quick guide to doing a hard Reset for the Aquaero 5 (It's the same for all variants of the Aquaero)...
N.
pegleg
jeudi 29 août 2013, 19:09
ok,thanks alot
pegleg
vendredi 6 septembre 2013, 16:49
well,i did a hard reset and i still can't get the flow to show up.i guess i will have to buy the new 6 when it comes out because something is wrong with the aquaero 5 or the flow meter
pegleg
dimanche 22 septembre 2013, 05:04
when i plug my aquastream xt pump in when i first start computer it will say found new hardware but when the flow sensor plug in all by itself it will not say this so can the flow sensor be bad?
pegleg a envoyé l’image suivante :
Discussions similaires
