• 22.11.2026, 21:28
JinTu
vendredi 23 août 2013, 18:27
running 12 hours without problems ..
Glad to hear it!
Let it run over the weekend, and if there aren't any glitches we can call it good enough.
In the mean time, I will be adding more device names to the output, then updating the SNMP export script and Cacti templates. Next up is adding support for setting the device names...
Raptor 2101
lundi 26 août 2013, 08:56
ok no problems during the weekend. seems stable
JinTu
lundi 26 août 2013, 13:38
Glad to hear it!
I'll roll up my devel branch to my main. The SNMP stuff and templates aren't done yet, but I added more the device names to the output.
Raptor 2101
lundi 26 août 2013, 16:13
Glad to hear it!
i will adopt this to my munin plugin...
Raptor 2101
jeudi 29 août 2013, 21:49
I post you a PullRequest
aerocli got some problems while handling characters like 'ä' 'ö' 'ü' (and i guess other utf8-characters...)
JinTu
jeudi 29 août 2013, 22:01
I'll have a more comprehensive look at your pull request tonight when I get a minute. It looks like it only affects the Munin plugin so it should be fine as long as it works for you.
Can you describe what you are seeing wrt the UTF8 handling issue? I assume this would only affect device names.
Raptor 2101
jeudi 29 août 2013, 22:48
i see somithing like this
Code source
1
FAN3.label L�fter HDD Oben
and yes i've only pull a change to the munin plugin
JinTu
vendredi 30 août 2013, 01:05
Code source
1
Can you send me the full output from one run of my sandbox test app were were using earlier to prototype the sensor name retrieval code? I need to see how the data is being stored in the Ae5 to figure out the best way of dealing with it.
Raptor 2101
samedi 31 août 2013, 00:04
here you go:output.txt.zip
JinTu
samedi 31 août 2013, 01:32
Code source
1
Code source
1
82:Lüfter HDD Oben (15 bytes)
Hmm, this looks like it is working with the test app and aerocli is handling device names in pretty much the same way. Can you confirm that this is actually an aerocli output issue and not an issue with your plugin or terminal settings?
Ce message a été modifié 1 fois. Dernière modification effectuée par "JinTu" (31 août 2013, 01:37)
Raptor 2101
samedi 31 août 2013, 21:14
youp, output createt by aerocli -o export ...export.zip
JinTu
samedi 31 août 2013, 21:40
youp, output createt by aerocli -o export ...[attach]4298[/attach]
It looks good as far as I can tell:
Code source
1
FAN3_NAME='Lüfter HDD Oben'
Raptor 2101
samedi 31 août 2013, 22:04
i got the problem, the special characters are encoded in ISO-8859-15 instead of utf8
try to bypass this in my plugin
JinTu
dimanche 1 septembre 2013, 20:45
Yep, looks like you are right. Lüfter HDD Oben in hex as sent by the Ae5 is 4C FC 66 74 65 72 20 48 44 44 20 4F 62 65 6E. The special character ü in UTF-8 is C3 BC in hex, but in ISO-8859-1/ISO-8859-15 (and 8-bit Unicode) is FC. This displays properly in my terminal and apps that consume the aerocli output as-is.
Raptor 2101
dimanche 1 septembre 2013, 22:52
ok fixed in my plugin. Pull request is out
JinTu
lundi 2 septembre 2013, 22:48
FYI: Lynix recently committed the first version of aq5rpcd to his devel branch of aerotools-ng which provide JSON RPC functionality for the Ae5! It still needs some work, but shows the potential of aerotools-ng.
This optional module relies on jsonrpc-c which has it's own set of dependencies which may take some work to get installed properly. Additional details of how to build and run are in the jsonprc-c and aerotools-ng README.
Once you have aq5rpcd compiled, to exercise the functions with 'nc' you can do the following:
Code source
1
2
3
4
5
echo "{\"method\":\"getFans\"}" | nc localhost 9090
echo "{\"method\":\"getSensors\"}" | nc localhost 9090
echo "{\"method\":\"getFlow\"}" | nc localhost 9090
echo "{\"method\":\"getDeviceInfo\"}" | nc localhost 9090
echo "{\"method\":\"exit\"}" | nc localhost 9090
FYI: I will be travelling overseas for the next couple weeks and will likely not be able to do much work on aerotools-ng during this time. Apologies in advance for any delayed responses.
appel
jeudi 5 septembre 2013, 20:02
I just bought a
aquastream XT USB 12V Pumpe - Standard Version
planning to also buy the
Flow sensor mps flow 200, G1/4
i got the pump running, and connected it with usb.
on windows i can controll it.
running linux debian 3.10 kernel.
is there something i have to test?
(tried to run the code from github but it gives errors)
Ce message a été modifié 1 fois. Dernière modification effectuée par "appel" (6 septembre 2013, 00:30)
JinTu
vendredi 6 septembre 2013, 19:48
I just bought a
Hi appel,
We need some additional detail on what version you are running (official rc0 or one of the devel branches) and details on any errors you get compiling/running to assist further.
appel
vendredi 6 septembre 2013, 19:57
running Linux isla 3.10-1-amd64 #1 SMP Debian 3.10.3-1 (2013-07-27) x86_64 GNU/Linux
jessie/sid
make all went fine
then i execute the next command
./aerocli -d /dev/usb/hiddev1
No Aquaero 5 found on /dev/usb/hiddev1. Found vendor:0xc70, product:0xf0b6(0xfffff0b6), version 0x100 instead
failed to poll: (null) (Bad file descriptor)
i guess i should change something before i doe "make" so it searches for aquastream XT and not aquaero
edit:
running from this
Git tree: main
https://github.com/lynix/aerotools-ng
Ce message a été modifié 1 fois. Dernière modification effectuée par "appel" (6 septembre 2013, 20:08)
JinTu
vendredi 6 septembre 2013, 21:43
jessie/sid
make all went fine
edit:
running from this
Git tree: main
Hi appel,
This error is telling you that the device on /dev/usb/hiddev1 is not an Aquaero 5 which is the only device currently supported by aerotools-ng (Aquastream XT is supported but only when connected via aquabus to the Ae5, not directly via USB). Since you didn't mention purchasing an Ae5, do you have one as part of your system?
Discussions similaires
