• 22.11.2026, 20:50
Shtanto
Best fan setup on a new radiator?
samedi 24 août 2013, 16:27
I'm setting up a 240XT with 4 fans because I can, though I might not need all 4 for running. What I'm wondering is whether or not it would be better to have air coming in from both sides or a setup where one pair push air through the fins and the other pair pull. I'll set it up as push and pull for the moment and change if there's a good reason to do so. It'll be an easy swap. I haven't filled my loop yet.
Pilo
samedi 24 août 2013, 18:19
Two fans push the cooling air through the radiator fins and two fans suck, the now heated air, out again.
There is no better fan combination for a lamellar-radiator then this.
Shtanto
samedi 24 août 2013, 22:08
2 in, 2 out. Thanks. I'd pass aquadrops if I had any ^^
Next question: What do I do with my RPM signal cable? Do I use it to wire my pump to my motherboard or to my fans? Or should I simply leave it in the packet?
Discussions similaires
