• 23.11.2026, 00:17
WilliamClement
Aquaero + waterloop few questions
jeudi 5 septembre 2013, 22:45
Hello,
I am currently waiting for the release of the aquaero 6.
However I have a few questions sins I am currently thinking of getting my first
water loop.
1. Do i need a Aqua Computer D5 pump so i can connect it
to the fan controller or do other brands work as well? And if other brands also
works can I use the alarm/auto shutdown functions when the pumps fails? I don't
mind if i can't control the speed off the other brands pump. What are the specific benefits of getting an aquacomputer D5 pump? And if i the aquacomputer D5 do I need to buy a top cover too if i am using it behind a reservoir?
2. What waterflow meter do I need to buy that's
compitible with the aquaero 6 + using a D5 pump sins you have so many different
ones I don't know wich one I should get.
3. What's the difference in using 4-pin conectors instead
of 3-pin connecters on fans?
Namron
RE: Aquaero + waterloop few questions
vendredi 6 septembre 2013, 02:31
Hello,
water loop.
You don't have to use an AC D5 pump provided you also get the correct cable to connect what ever D5 pump you get to the Aquaero IE: from the pump Usually(Molex) to the Aquaro 3 pin fan connector something like THESE should do it & you can then connect the RPM plug to a Motherboard Header say like the CPU FAN header to monitor the pump & set a shut down set up through the Motherboard bios e.t.c..
If using a D5 pump then I would op for either THIS ONE or THIS ONE or indeed THIS ONE I wouldn't bother going with the lower flow MPS Flow Sensors because your planning on using D5 and depending on the loop your going to be pushing around from any where between 170l/ph > nigh on 280/300l/phr (all depending on how restrictive your loop is going to be really) thats a very rough guesstimate mind ;) ..
4 Pin Fans are usually PWM controlled & 3 Pin Fans are usually VOLTAGE Controlled for speed.... The Aquaero 6 will be able to handle both so the choice is yours really :)
I've Highlighted my responses as you can see :) ... Hope that helps..
N.
WilliamClement
vendredi 6 septembre 2013, 10:21
Thnx m8 this helps a lot.
Discussions similaires
