• 29.11.2026, 05:26
Hangman
Aquaero = Over-rated
jeudi 19 septembre 2013, 05:03
For ease of discussion and to avoid confusion, below is some graphic definition for words I be using in this write-out:
http://www.google.com/imgres?sa=X&biw=19…,r:27,s:0,i:167
In the picture above, the end of the cable at the right side, I will call it 4-pins female in this discussion. The other end of the cable at the left side, I will call it 4-pins male in this discussion.
Aquacomputer products I purchased:
http://www.frozencpu.com/products/13215/…t_Revision.html x01 unit
http://www.frozencpu.com/products/19440/…O_XT_53093.html x01 unit
http://www.aquatuning.us/product_info.ph…-interface.html x02 units
http://www.aquatuning.us/product_info.ph…-USB--G1-4.html x01 unit
http://www.aquatuning.us/product_info.ph…able-4-Pin.html x06 units
http://www.aquatuning.us/product_info.ph…able-4-Pin.html x05 units
http://www.aquatuning.us/product_info.ph…tra-series.html x02 units
The case I am using is the STH10, which is one hell of a monster. All cables inside are at least 100cm long. As such, I need REAL long cables, not just mere 70cm in length. I had tried to connect 2 y-splitter cables and 1 4-pins-female-to-4-pins-female cable (the one I purchased from Aquacomputer) together. Then I use them to connect the aquaero 5 xt and the USB Aquabus Flow Sensor to each other, but it FAILED!!!! I could not see “Flow 11” under the sensor tab nor can I see any flow reading on my aquaero 5 xt unit.
Shoggy offered the explanation that the cable combination of “2 y-splitter cables and 1 4-pins-female-to-4-pins-female cable” is too long and will affect the communication between the USB flow sensor and the aquaero 5 xt. I don’t accept this explanation. If this means re-arranging my rig to bring the aquaero 5 xt and the flow sensor closer together to be able to be connected by a shorter wire, I would say DREAM ON to aquacomputer. If anything, it is their products which failed big time. Am I the only one here feeling the rage?!
Next, the Aquaero 5 XT can be connected at a maximum of 4 MPS devices. If the y-splitter cable cannot be used, please enlighten me how the hell you going to connect 2 USB Aquabus pumps, 1 USB Aquabus flow sensor and 1 poweradjust 2 ultra to the aquaero 5 xt? And oh hell, the poweradjust 2 ultra have got the 3-pins male and NOT a 4-pins male; according to manual, you are suppose to connect the 3-pins-female-to-3-pins-female aquacomputer cable (the one that come with your poweradjust 2 ultra purchase) to the 4-pins male high-speed aquabus port on the aquaero 5 xt. How the hell you going to do this and even if you can, how are you going to connect all 4devices to the aquaero 5 xt without using any y-splitter cables?????
I am now sourcing for a Aquacomputer fanboy to sell away all my aquacomputer products. Damn you Aquacomputer! You just robbed me of my precious time, effort, money, and ignite the rage in me! I will never ever touch your products ever again and I will honor my words and spread your notorious products quality to where I came from.
I am not one who drop cash on some premium products and find thrill in wiring them up and troubleshooting them. I am also not one who will just fuxk it, forget it and swallow the idea that the premium products which I bought using good money just happen to malfunction.
cc01
jeudi 19 septembre 2013, 06:34
The 3-pin cable will connect to the 4-pin Aquabus port without any problem.
Why can't you move your flow sensor closer to the XT?
jeudi 19 septembre 2013, 07:17
The total length of aquabus is limited.
When you have to much devices on the aquabus you have to decrase the cable lenght.
The differece between 3 an 4 pin aquabus connections is the power supply.
Wenn you connect a 3 pin cable you have to attach a seperate power supply. When you use the 4 pin cable the device is powered from the aquaero.
Wehn you use Y spliter cables or extensions you have ensure that pins conncted.Some cables connect only 2 of 3 pins.
To find a error you have to diconnect the bus an test each device seperate on the bus. One defect device on the bus can disturb the bus an no device can answer.
This is a bus shematic from us: http://aquacomputer.de/downloads/aquaero5_aquabus.pdf
Pilo
RE: Aquaero = Over-rated
jeudi 19 septembre 2013, 10:40
When I'm reading such bullsh**, the only thing I can do is "Laugh Out Loud" and make a run-up facepalm. OMFG! The only one at fault is not Aqua Computer, but people like you who blindly buy products and do not get informations about the products beforehand. Projecting your way to exaggerated expectations on a product that itself is limited because of his design and above all the parallel bus design, man, I could've predicted this in advance. The old and yet outdated Parallel ATA (IDE or Integrated Drive Electronics, 1989) for Harddisks, Optical drives etc. is also a parallel bus and is very very limited, especially the max. permitted cable length of just one meter and for just max. two devices. That's the nature of a parallel bus. IDE/EIDE/PATA/ATA/ATAPI back then, was the only way to connect your drives, you had to live with it, there was no other option and nobody falsely blamed the inventor for it. It's the same with the Aquabus. There is no other option, you must live with it. Period!
Go and read about the differences of a serial bus and a parallel bus and their other pros and contras and then be ashamed of yourself for blaming others for your own mistakes, lack of knowledge, misplanning and mispurchase after that.
P.S. You can only blame Aqua Computer for the really really really poor documentation, especially for product limitations and their dimensions. It would be much better to have step-by-step instructions or some how-to's. That would be some real help, because the forum overflows of the same repeating novice questions.
P.P.S. I myself am not totally satisfied with the limitations of the Aquaero and the Aquabus and I already approached Aqua Computer several times to modernize the Aquaero to make it more versatile and easier to use. But that isn't as easy as that, the costs for an Aquaero with serial Aquabus for example would be much much higher and just for some unusual exceptions like yours not profitable enough. It would be a high price product only for enthusiasts and geeks with to much time & money.
Namron
jeudi 19 septembre 2013, 11:53
I have in total 5 x y splitter 4 pin cables, 4 x extension cables 4 pin & 3 pin (70cm).. An Aquastream XT Ultra & USB/Aquabus D5 Pumps, 2 x Power adjusts, 2 x High flow Meters (old type) 1 x MPS 200 Flow meter, 2 x MPS Fill level sensors & a Aquaero LT (as a Slave device) all connected to one Aquaero 5 Pro. Everything is working as it should.. Some Items are connected Via the USB & Aquabus simultaneously & some just Via the Aquabus e.t.c..
It's been my experience that provided you follow a few simple but very important guide lines, such as making sure there is no power & the main Aquaero unit along with any add ons are Disconnected from any power source before you start to connect things up, You'll go along way to Alleviate many problems that can occur...
There are several Guides out there that could have helped you right from the beginning (I've written one or two things myself as regards the Aquaero e.t.c). I'm for ever changing things & having to re-cable things as & when I Review or try out various AC gear for the Aquaero, Where I don't deny it can be a bit of a minefield to set somethings up & to get your head around things, It is very Possible to do without Loosing your rag & blaming All the equipment & not maybe look at how you went about connecting & setting things up... I have certainly never seen anywhere were it says the Aquaero e.t.c is a Plug & Play type thing..... Surely you must realise that something this complex to monitor & control so many items is going need a little forethought & thinking about before you fly in there all guns blazing and not expect problems??..
I don't know, Maybe you had a dodgy component or one of the leads was Naff, Maybe you attached a connector to the wrong header (easily done when your eager to get the thing up & running) The Aquaero is very iffy about having things connected wrongly or when it's still connected to a power source e.t.c.. Which is why I always stress to people to Ensure they have all the AC units disconnected from a power source before you ever begin to connect things up....
I'm sorry your so angry & blame AC for all your woes, But I feel ranting & raving like this just doesn't achieve anything or gain you much respect as regards to someone helping you out..... When the product is connected up & set up properly it for the most part works very very well Indeed as Thousands of people have found... :) ..
Good luck..... & maybe pop a Happy Pill..... or Two ;) ...
Hangman
RE: RE: Aquaero = Over-rated
jeudi 19 septembre 2013, 21:15
P.P.S. I myself am not totally satisfied with the limitations of the Aquaero and the Aquabus and I already approached Aqua Computer several times to modernize the Aquaero to make it more versatile and easier to use. But that isn't as easy as that, the costs for an Aquaero with serial Aquabus for example would be much much higher and just for some unusual exceptions like yours not profitable enough. It would be a high price product only for enthusiasts and geeks with to much time & money.[/quote]
I can't believe what i had just read. You expect the people out there to know about "The old and yet outdated Parallel ATA (IDE or Integrated Drive Electronics, 1989) for Harddisks, Optical drives etc. is also a parallel bus and is very very limited, especially the max. permitted cable length of just one meter and for just max. two devices. That's the nature of a parallel bus. IDE/EIDE/PATA/ATA/ATAPI back then, was the only way to connect your drives,"? I can readily lay a bet with you more than 50% of the enthusiasts out there don't even know all these shit. Are you game on for the bet? And what do you mean i have to live with it? This is a democratic world we live in, and i don't have to live with anything i hate or dislike. My time is better spent making more money than reading up on this serial and parallel bus crap. The only thing i can be ashamed of is when i earn lesser money than others. Period.
If Aquacomputer seriously think PC hardware enthusiasts are going to mug through the WWW to read up and learn about all the tiny explicit details about how to wire up an Aquaero, then it is set for DOOM. Mugging and studying up wires, parts are things of the past. People nowadays want it fast and straight. Thats the reason why plug-and-play devices are selling like hotcakes now. Digging up, exploring and analysing which wires going where and which pins does what just happens to be your fetish - a RARE fetish. Your mentality is that although my hardware may not be the highest end, i pride myself on being able to wire up my aquaero. Thats a fake sense of self-satisfaction. Someone with a 3970x or quad sli titan is still going to beat you straight in this hobby. Get it?
But you all know what, i managed to locate aquaero fanboy over at my end who is going to buy over all of my items with just 10% loss off the purchasing price. I am going to do a writeup about how screwed-up Aquaero lines of products are and ensure no one from my side of the community ever get cheated into buying any of these bullshit products. Period.
Hangman
jeudi 19 septembre 2013, 21:22
I think it is a real joke that Aquabus wire can't hold the connection when the cables get too long. Try telling others about this. I buy a product to make thing runs smoother. I don't buy a product and end up having to tweak and accommodate its crap.
Hangman
jeudi 19 septembre 2013, 21:26
Am i suppose to transform myself into an engineer and study and know all these to fix up my pricey aquaero products?
cc01
vendredi 20 septembre 2013, 15:39
A three year-old's tantrum may be excused on account of his or her emotional inexperience, but coming from an adult on a public forum it is plainly ridiculous. :thumbdown:
scorp
vendredi 20 septembre 2013, 21:58
You would be ashamed if you made less money then others .... hahahahahaha
better transform that line into:
You should be ashamed why you cant get things to work while others do
You have chosen the wrong hobby hangman.
Ce message a été modifié 1 fois. Dernière modification effectuée par "scorp" (21 septembre 2013, 14:38)
mandrix
dimanche 22 septembre 2013, 14:44
Mmmm.
Ce message a été modifié 1 fois. Dernière modification effectuée par "mandrix" (23 septembre 2013, 13:04)
LotusOmega
dimanche 22 septembre 2013, 22:16
I second that AC provide very poor documentation on their premium products and I really do not understand why they continue to do so and prevent these kinds of rage forum posts. It's not the first one I've read! In this case an online product manual displaying a simple table describing number of aquabus units connected to the Aquaero with recommended maximum total aquabus length could have prevented this - assuming customers put some effort in preparatory readings before clicking the buy button. You honestly should not have to find out through forums that there's an invisible warning label on the product you have bought.
For my own part I like fiddling with things and learn stuff by doing (and failing) so I was excited when AC announced the new Aquaero 6 series. But now that I know about the aquabus total length limit (I certainly did not know about it until I read this post) it made me think twice about using the new Aquaero 6 XT in my upcoming Caselabs TX10-D project. I now have to measure and be sure that all the different peripheral sensors I was planning to integrate is placed within an Aquaero radius of ~1 meter(?), perhaps even including a safety margin (70 cm seems to work fine with a busy aquabus...) and I do not want my build to be affected by an aquabus total length limit restriction. Running a ton of permanent USB cables to replace aquabus is undesired.
Let's see if the AC-guys have put some effort in providing a more detailed manual for the aquaero 6 series
:whistling:
mandrix
dimanche 22 septembre 2013, 22:49
I think we can all agree better documentation would be welcome. I won't say I struggled a lot, but I have asked the AC staff questions from time to time.
cpachris
lundi 23 septembre 2013, 17:07
........ in my upcoming Caselabs TX10-D project.
** head turns quickly ** your upcoming what?? buildlog will be where??
bern43
lundi 23 septembre 2013, 17:45
Better documentation would be welcome. But the support I've received, especially from Shoggy, has been outstanding. He always patiently answers all the silly questions I have. Part of the "fun" in using this stuff is that it's not plug-and-play. In exchange for a lack of simplicity you get equipment that provides a level of control and monitoring that is far ahead of almost anything else. I'll take the trade-off.
LotusOmega
lundi 23 septembre 2013, 23:51
In addition there are a lot of good and useful information floating around the net, if you bother to do a proper reserach before committing to buy. I've collected a ton of inforamtion about AC products, gathered from different buildlogs and based on pros and cons of readings; I too will take the trade-off.
TX10-D project. OCN - If I decide to do a buildlog, haven't made up my mind yet...
frank anderson
vendredi 27 septembre 2013, 02:47
I'm running a Aquaero 5 XT and 6 PA2, attached to dual loop, quad AC D5 and more cables then a bowl of spaghetti, prior to doing all this, I did about 2 weeks worth of research and asked shoggy and another member of this community about 50 questions, Aquaero is a very advanced product and once running, it just knocks the socks off from anything that is out there at the moment, just take a step back, putting a rig together of this magnitude is not something that can be rushed into, ask the community and there are many helpful members that will share their experience and help you get your rig up.
Discussions similaires
