• 12.11.2026, 19:45
pumba2988
Power Adjust?
mardi 8 octobre 2013, 23:28
Okay I need to find out what on earth does a
Poweradjust 2 USB do exactly?
Also why do you have to buy 3 separate to be screwed together in one 5.25" Bay Device.
Also what is the point of the
Multiswitch?
Thanks :thumbup:
Nihil Simile
mercredi 9 octobre 2013, 03:28
You don't need three, The Power Adjust is the same as a fan header on the Aquaero 5 XT , Pro, or LT when it is connected to the aqua bus High side header on the Aquaero also called aqua bus #2. It can handle more amps so you can control a pump or a large fan with it. When connected to the Aquaero via the aqua bus High Side header it will show up as fan 5 you can change this to Pump in the Aquaero menu. If you need to power more high amp accessories then you add more Power Adjusts.
pumba2988
mercredi 9 octobre 2013, 09:52
Thanks i feel so noob right now :(
well as they always say knowledge is power :D
