• 13.10.2026, 09:54
CoolCat
simple question, instilation of a flow meter
vendredi 11 octobre 2013, 06:30
i have this flow meter http://shop.aquacomputer.de/product_info…roducts_id=1655 and in my haste to unbox i have since lost/misplaced instruction and i am wondering can this sort of flow meter work on its side or on its back end pointing up, or must it be installed flat to the bottom of the case
Grasshopper
dimanche 27 octobre 2013, 08:10
I think you will find it is very similar or identical to the unit used in a hig-flow flow meter.
I have used my high-flow vertical mounted and horizontal (current build) with no issues.
  • I do not hard mount it to the case as people report ticking noise from some units, I support it with soft foam.
  • I have always avoided tight bends close to the high-flow as I assume increased turbulence will increase noise
  • I calibrate it to the software I am using, for its information to be meaningful.
Discussions similaires
