• 15.11.2026, 21:24
delevic
High flow meter usb not working after one day
dimanche 27 octobre 2013, 00:49
I have aquacomputer high flow meter usb. After a day of work, I stopped to get flow-information. I also noticed irregularities in the readings of water temperature. It is quite slow to react to changes and gave the incorrect temperature +-1.2c. I compared with three thermometers ..... I reinstalled netframework 4.5.1 , and aquasuite... What to do ?
Best Regards
Delevic
Ce message a été modifié 1 fois. Dernière modification effectuée par "delevic" (27 octobre 2013, 09:45)
b0nez
lundi 28 octobre 2013, 15:50
Simply open your flow meter. See if the prop which is inside get stuck. If so, remove an clean it.
:rolleyes:
sylvainp
RE: High flow meter usb not working after one day
samedi 2 novembre 2013, 06:40
Best Regards
Delevic
Go in the sensor pages and select the Flow sensor temp and look on the right you can make a temp offset.
delevic
samedi 11 janvier 2014, 13:56
It was hardware issue. It is fixed by aquacomputer :)
