• 03.10.2026, 01:45
slyfirth
new member
lundi 4 novembre 2013, 17:38
hi all new member just a quick one got a aquaero 5 pro also got a inline temp sensor is it ok to fit on radiator out let has I do not want to put it on my cpu block (o ring does not look good on it to say its new but get one from work)
cc01
mercredi 6 novembre 2013, 10:15
Yes, it is okay to put the inline temp sensor on your radiator outlet.
I'm sure you're not texting to this forum so it would help with understanding what question you are asking if you wrote in sentences, even if they are brief. Thanks. :)
slyfirth
lundi 11 novembre 2013, 23:23
ok thanks for your help :D
slyfirth
lundi 11 novembre 2013, 23:29
just looking at the manual ?
lots of bits to this unit is there a more indepth manual two help ?(
Discussions similaires
