• 17.11.2026, 02:37
lundi 25 novembre 2013, 13:19
Try it to update on an other computer.
Traches
mercredi 1 janvier 2014, 00:10
I'm having a new issue since updating - my software sensors don't work anymore!
I'm using Open Hardware Monitor; I've tried clean installs of aquasuite, the aquaero 5 LT firmware & settings, and OHM. OHM reports various system temperatures, but the aquasuite software reports only the fallback temperature. (I set the sensor to enabled, check the "use with service" box, and select a data source from the OHM list that shows up.)
Anything I should try?
Edit: Here's a screenshot for clarity.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Traches" (1 janvier 2014, 00:16)
wa3pnt
mercredi 1 janvier 2014, 03:52
I had unreliable operation using OHM also. Bit the bullet and purchased aida64. Now solid as a rock.
I only wish the ASUS Crossfire Formula V -Z motherboard offered more software temperature sensors like the VRM and NorthBridge.
RodeoGeorge
bcikota
mercredi 1 janvier 2014, 04:24
I had a similar problem after upgrading, noticed that the temperatures from AIDA did not show. Check under aquasuite\settings that the Aqua Computer Windows Service is installed and running.
Kind regards,
Boris.
Traches
mercredi 1 janvier 2014, 19:50
RodeoGeorge
I may end up doing the same, but it would suck to drop $40 and not have it fix anything! I'd really like to control a couple of my fans based on HDD temp.
Kind regards,
Boris.
Thanks!
Service is installed and running, and I've tried stopping, uninstalling, reinstalling, and restarting it (along with several other combinations of computer and aquasuite restarts.)
josetortola
mardi 6 mai 2014, 20:20
Hello.
Please, forgive me for asking in my first post... but I'm looking for a detailed manual for Aquasuite 2014. I bought a unit Aquaero 6 PRO and I would like to learn how to take the maximum profit of it.
Google has redirected me to this post, but the links in the first post are not working. I've also tried to search in the main Aquacomputer.de web, but I haven't found it.
Is anywhere a detailed manual for the software?.
Thanks in advance.
Jose.
mardi 6 mai 2014, 20:24
you can download the manuals here: http://aquacomputer.de/handbuecher.html
josetortola
mardi 6 mai 2014, 20:35
Thank you for answering, that was fast! :)
But, despite of the facts that my German is as bad as my Chinesse and Google Translate is not always a good companion when searching, I've seen there manuals for all the "hardware" pieces, but no for the software "aquasuite" itself. Maybe not to find it It's my fault, but could you give us a direct link for it (if it exists), please?.
Thank you once again.
mardi 6 mai 2014, 20:39
The aquasuite has no seperate manual. The software is explained in the seperate device manuals. For aquaero use the aquaero manual.
josetortola
mardi 6 mai 2014, 21:04
Wow, that's a shame.
Thanks a lot for answering. I'll read again the Aquaero 6 PRO manual, but it doesn't have all the information for the software.
Maximization
mercredi 7 mai 2014, 03:28
guys when i did a software check i got this screen , do aquastream ultra users have to worry?
Maximization a envoyé l’image suivante :
mercredi 7 mai 2014, 07:01
This is the aquasite 4, use the actual version "aquasuite 2014"
