• 29.11.2026, 09:51
Harry247
Do i need the front-panel switches?
samedi 11 janvier 2014, 15:42
Currently i am building a custom case with a acrylic front panel.
My plan is to place the aquareo 5 pro inside the case, so you can see the display through the panel.
The result is that the 3 buttons aren't usuable without opening the case.
My question is; is the aquaero completely controlable through the AS, or do i need the buttons for some reason?
DarkRanger
samedi 11 janvier 2014, 20:20
I also got a Aquaero 5 Pro, and as far as I know, everything setting is available through the Aquasuite except the 4 profiles that can be set in your Aquaero that you have to save and load via the front panel.
Hope this help!
kpoeticg
lundi 20 janvier 2014, 00:50
You could always buy the controller for it too. It works with the Pro's as well as XT's
Discussions similaires
