• 11.10.2026, 05:17
Railgun
mardi 21 janvier 2014, 22:07
Second time now...took about 45m or so before the issue popped yet again.
I also think the issue still remains. Updated and the issue reoccurred until I restarted the service.
Yes, restarting the service only works a short time for me, then back to defaults.
mardi 21 janvier 2014, 22:08
We will have a look on Aida tomorrow.
Seanimus
mercredi 22 janvier 2014, 05:15
1-2 is getting worse. Now with new firm ware ...The RGB outputs are all messed up.
wa3pnt
mercredi 22 janvier 2014, 05:57
I have had 2014-1.2 running for 20 hours, using aida64 as the source for the Software Sensors.
It has been solid, with no loss of inputs
I did have to restore the RBG settings for the Controller. The Blue was 100% for Low, Medium, and High. Once I corrected this, the RGB control has been good.
I have found no other problems with 2014-1.2 (Controlling 2 - Aquastream XT Ultra, 2 - MPS400 Flow Ultra, 2 - Poweradjust 2, 6 - PWM Fans [on Fan 1, 2, & 3], and 2 - RGB LEDs using a Wye).
RodeoGeorge
Ce message a été modifié 1 fois. Dernière modification effectuée par "wa3pnt" (22 janvier 2014, 06:00)
Seanimus
mercredi 22 janvier 2014, 06:02
RGB for me so erratic. Fans are stable after reboot on controller. The RGB outputs are not. I have a more elaborate RGB setup .
Will test again tomorrow.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Seanimus" (22 janvier 2014, 06:04)
mercredi 22 janvier 2014, 07:52
For the most time it is stable, but we have found another issue. We will release today - after some tests - a new version with a more stable aida import.
The problem is that aida exports the values not in the normal way (like most other software that writes to wmi).
EDIT: the new version with the aida and OHM fixes is online now.
Seanimus
jeudi 23 janvier 2014, 02:23
Sorry guys for misreporting. The issue was the temperature of CPU was 19C reporting out of AIDA64. And all my controller profiles were starting from 20C got reset.
All working fine for last hour.
Aemonn
jeudi 23 janvier 2014, 04:42
I'm also having a horrible time with the 2014-1.3 version and the 1036 firmware version.
After upgrading and flashing, I'm having the same issue with the software sensors freezing their output. I also discovered restarting the service got things moving again but the problem would re-occur after a while. I tried completely uninstalling the application and service and re-installing but the issue persists.
Now, the really strange thing I've found is that since upgrading, my time in windows gets changed. This correlates to the freezing of the software sensor readouts in aquasuite (they both happen at the same time). I have tried disabling the software sensors and closing aida / hwinfo (i only ran them individually, never together) but my time still changes.
I'm in the process of running my system without aquasuite open to see if my time still changes. If it does, my next step will be to uninstall or disconnect the USB header and see if it persists.
I know this sounds really strange. I work in IT and already know you guys will be thinking i'm nuts! The only thing that has changed on my system by my hands in the last two weeks was this software update. Has anyone else noticed an issue with their clock changing?
I'm running Windows 7 X64 and an aquaero 5 LT.
Ce message a été modifié 2 fois. Dernière modification effectuée par "Aemonn" (23 janvier 2014, 05:01)
wa3pnt
jeudi 23 janvier 2014, 05:30
As I mentioned earlier, I'm running Aquasuite 2014-1.3 with several components (two each Aquatream, Poweradjust and MPS400) and it has been stable with no Software Temperature Sensor dropouts.
I'm running Windows 8 64Bit, ASUS Crosshair V-Z, and FX8350. I'm using aida64 (Version 4.00.2752 beta) for the software sensor source.
I've had it up, uninterrupted, since the download was posted.
RodeoGeorge
Railgun
jeudi 23 janvier 2014, 11:51
I gave it about a 90m test last night and all seemed ok.
mandrix
jeudi 23 janvier 2014, 17:17
Everything seems to be working fine between Aquasuite 2014 1.3 software temps and AIDA 64 for me.
Aemonn
jeudi 23 janvier 2014, 23:12
Yeah there something else going on with my system. Might be time for a fresh install of windows. Disregard my previous post!
Seanimus
vendredi 24 janvier 2014, 02:06
Working fine on Admin account.
I don't know where following issue lies..whether Win7-64 or Aquasuite or Aida64
If I have 2 accounts. Admin (mine) and Regular user (my son).
If I log into Admin Account and then switch to Regular account it is fine.
However on cold restart going directly to Regular account it seems Aquasuite cannot read WMI from Aida64. If I check in Aiad64 directly the sensor values shows correctly; but in Aquasuite all at 50.
Any thoughts?
wa3pnt
vendredi 24 janvier 2014, 03:03
Go to Control Panel > Administrative Tools > Computer Management > Task Scheduler > Task Scheduler Library and look at the Trigger Actions for Aquasuite.
If you double click Aquasuite in the Library you can edit the settings.
Ensure that it is set to Trigger = At Logon, and Details = At logon of any user.
Also under Trigger you can set a delay to allow programs like aida64, OHM, or hwInfo to load before Aquasuite.
RodeoGeorge
Ce message a été modifié 2 fois. Dernière modification effectuée par "wa3pnt" (24 janvier 2014, 03:06)
mandrix
dimanche 26 janvier 2014, 15:25
Aqua Computer service stopping intermittently....and I lose input from AIDA 64. I have to manually restart the service.
Win 7 Pro 64 bit.
Seanimus
lundi 27 janvier 2014, 02:34
Mandrix i hope you find solution.
wa3pnt: thanks for pointing me in the right direction.
Just to add some other settings I did, in addition to "At logon of any user" in Triggers.
In General Section:
When running task use admin user name (this is by default
The radio button I selected "Run whether the user is logged on or not".
I did not select "Do not store password...".
On clicking OK...I was prompted to enter the password, even though on Admin account.
Now it works on two other regular user accounts.
mandrix
lundi 27 janvier 2014, 02:50
Hi Seanimus. It all worked fine before the recent software changes. Now the service stops occasionally and has to be restarted manually. strange. :sleeping:
mandrix
mardi 28 janvier 2014, 02:15
Anyone else having problems with the Aqua Computer service stopping, seemingly at random?
I have been unable to associate it with any specific event so far.
Seanimus
mardi 28 janvier 2014, 17:27
My son's gaming for hours and it seems fine on the S5 build. Win7-64 bit and Aida 64 release version (not beta).
mandrix
mardi 28 janvier 2014, 18:17
I have a registered version of Aida 64 Extreme, but no joy.
I had no problems before the recent (2014) Aquasuite changes, it always worked flawlessly with Aida. There appears to be no way to downgrade to previous firmware/software versions of Aquasuite that DID work.
But hopefully it will all get straightened out......
