• 09.10.2026, 10:48
Seanimus
mardi 28 janvier 2014, 19:24
Did you try uninstalling and reinstalling Aida 64. I did that on mine (because I was playing with HWInfo). Worth a shot. Maybe Aida values going over to Aquasuite is messing up the process to fail.
mandrix
mardi 28 janvier 2014, 21:31
I just installed the latest Aida64 update, I'll see what happens the rest of the day.
Mega Man
vendredi 31 janvier 2014, 09:19
another bug to report
using the remote when i press y it inputs z, when i press z it inputs y
vendredi 31 janvier 2014, 10:10
You have to change the keyboard layout from german to english in the IR Menu on the device.
Mega Man
samedi 1 février 2014, 08:43
Thanks for the quick response !
mandrix
dimanche 2 février 2014, 01:45
The Aquacomputer service is still stopping randomly....sometimes it can't be restarted without rebooting. This means all data from Aida 64 stops being displayed.
Also, one of my flow gauges on the desktop is still dropping to zero also at random, although inside Aquasuite it works just fine.
I have even done a clean install of Windows 7 Pro x64 since I was setting up a new RAID, and still have the problems.
Again, this has only been happening since the release of Aquasuite 2014....Aquasuite 2013-5.2 was working fine.
Is this being worked on at all, or does Aqua Computer consider the Aquasuite problems "fixed"?
Seanimus
dimanche 9 février 2014, 17:00
Any luck Mandrix?
mandrix
dimanche 9 février 2014, 17:07
Well actually it seems to be doing pretty good now.
What I did was switch from Aida to HWINFO for a bit. Then IT started giving problems, so I switched back to Aida again and so far seems to be doing fine.
Go figure. Some little software or driver quirk I guess.
Seanimus
dimanche 9 février 2014, 19:20
Thats when mine started working. Lol. Switched between Aida to HWInfo and back.
mandrix
dimanche 9 février 2014, 20:12
lol. Makes you wonder, don't it?
But as long as it works, I'm happy.
mandrix
dimanche 9 février 2014, 20:18
Aaargh! I guess I spoke too soon. After working fine with Aida for several days, the service just quit. Mmmmmmmm!
Seanimus
dimanche 9 février 2014, 20:26
Sorry, but I couldn't help it and laughed.
mandrix
lundi 10 février 2014, 00:06
I might as well laugh too, it doesn't do any good to get mad. :)
felixar90
lundi 10 février 2014, 08:06
I'd like to report a bug.
I have 3 GPUs, and I am using HWInfo64 to monitor my sensors.
I created 3 software sensors, one for each thermal diode, but they actually all read the data from the GPU #0.
Whatever sensor I select for GPU #1 and #2 actually read the equivalent data from the GPU #0.
I would use Open Hardware Monitor, but it's too old and it doesn't work with my 4960X
Seanimus
mercredi 12 février 2014, 23:13
AIDA64 update released today. Try that Mandrix.
mandrix
jeudi 13 février 2014, 00:03
Yep,I always keep it up to date.
Something I noticed today, seems to happen mostly after waking from sleep, the Aqua computer service will be stopped.
jeudi 13 février 2014, 07:38
Windows has many sleep / power off modes. Which mode are you using?
mandrix
jeudi 13 février 2014, 17:33
Well that's a good question. Even though Hibernation is supposed to be turned off, the other day I could not wake the pc from sleep and got a message that seemed to indicate the computer had entered hibernation.
So I disabled hibernation from the command line and I will see how it goes. Otherwise sleep is enabled in Windows 7 power options.
In the BIOS ErP is disabled, and C6/C7 is Enabled to attain the low power idle on my Gigabyte Z87 board.
Seanimus
jeudi 13 février 2014, 18:29
I gave up on Sleep mode for EVGA motherboard. Too many issues with memory/usb failures after waking up from Sleep. I just do complete reboots.
mandrix
jeudi 13 février 2014, 18:47
Well sleep has been working fine for me except for a short time when I suspect a beta bios screwed things up. But I can usually work around the problems and get things working again eventually.
I made some tweaks, so I'll give it a chance to sleep on and off the rest of the day and see if everything recovers as it should.
