• 11.10.2026, 11:47
Badkarma
First post :) Part check
mardi 25 février 2014, 16:15
So I finally picked up a 6 XT for my upcoming rebuild (yay) and I wanted to check on what flow sensor I should get.
My noobishness is telling me this one http://shop.aquacomputer.de/product_info…roducts_id=2294
however I wanted to check here and make sure. Seeing the USB port models kinda confused me a bit. I just want a simple flow sensor, it does not have to have all the bells and whistles.
best regards..
bcikota
mardi 25 février 2014, 21:00
Hello Badkarma,
If you want a simple flow sensor, the one you chose is right. It is a "mechanical" model, the flow is measured by a rotating impeller. As such, it may produce some noise, with some of them reported to be "clicking" sometimes. I have one and I'm very happy with it. You connect it to Aquero over aquabus.
The USB model is an upgrade to the previous one, with the MPS controller part integrated in it. It basically allows you to run it even without Aquaero, just connected over USB, or even standalone.
The MPS models use a differential pressure to measure flow, so there are no moving parts. This means they are noiseless and should be less prone to failure, although I read about some problems with leaks due to the missing or damaged seals.
Any of these will do a great job, but as you want and need the basic version I think you made the right choice.
Kind regards,
Boris.
mandrix
RE: First post :) Part check
mercredi 26 février 2014, 01:31
best regards..
I have two of those. They work fine and make no noise, although some people have said theirs make a clicking sound.
Badkarma
mercredi 26 février 2014, 03:28
Very informative posts here. Thank you very much :-)
