• 22.11.2026, 23:23
Shizbazki
Aquacomputer D5 Temp lead
mercredi 26 février 2014, 23:48
Hi all
So i have gotten my Aquacompter D5 with USB and Aquabus, working great after installing the whole thing but i have noticed that the Temp connector has no lead provided, i have looked on ebay and various other resellers and cant find a female or female 2 pin temp lead.
Anyone know where to find one??
bcikota
jeudi 27 février 2014, 09:56
Hi Shizbazki,
That connector is used to connect a temperature sensor to it, which can then be used to control the pump.
So, you would need this or similar.
Kind regards,
Boris.
mandrix
jeudi 27 février 2014, 16:23
Yes, like bcikota shows. Basically all the 10K ohm sensors...they are available from Aquacomputer, Phobya, etc. and vary in price and/or length.
There are also fittings that can plumb right into a water cooling line, that use the same sensor wrapped around a fitting to measure the coolant temperature.
Shizbazki
jeudi 27 février 2014, 17:20
Oh right, I thought it was a built in temp sensor for the D5 which would connect to my Aquaero 6xt temp sensors.
Discussions similaires
