• 11.10.2026, 13:53
tbduk75
loosely fitted bracket/wings on Aqua Computer Cuplex Kryos HF - by design or factory assembly issue ? [SOLVED]
vendredi 28 février 2014, 00:44
Hello everybody. Noob here! And very thankful I am to have found the English forum.
I have a question please about my Cuplex Kryos HF. The mounting brackets (wings ?) attached to the block have some room to move/wiggle. Even though the bottom of the waterblock is firmly attached. It feels like they need a washer/spacer to be held tight.
I found a review where the chap finds the same as me and gives these brackets a wiggle
https://www.youtube.com/watch?v=QD2YTc0GU3c#t=170
later in the video he tightens the bottom fitting very tight to entirely remove this play/wiggle room.
https://www.youtube.com/watch?v=QD2YTc0GU3c#t=468
My question then is:
Is it by design that there is a little play in these fittings (and so has the chap on youtube somehow bent the bottom plate by over-tightening ?)
I'd much appreciate your guidance.
Thanks in advance
Tim
Ce message a été modifié 1 fois. Dernière modification effectuée par "tbduk75" (3 mars 2014, 11:49)
tbduk75
SOLVED
lundi 3 mars 2014, 04:19
Hello Tim,
this is normal and no issue with the production. The brackets only lie between the top and the base and are hold in position by the screws from the base. Other than the parts of the block, the used material for the brackets has some small fabrication tolerances which in the end decides if it will sit firm or might have some play. Some play is OK while only a tad to thick could already bring up the problem that the base and top will be "pushed" away from each other - in an extreme case it would cause the block to leak.
Anyway, it is nothing to worry about and do not use any washer because then you might experience the problem that I wrote before. When you mount the block it will not move anymore and it also has no impact at all on the cooling performance.
kind regards
Sven Hanisch
Sven Hanisch
Vertrieb/Sales
Aqua Computer GmbH & Co. KG
Gelliehäuser Str. 1
37130 Gleichen
Tel. +49-5508-9749-290
Fax +49-5508-9749-291
Discussions similaires
