• 12.10.2026, 13:06
Ryanboost
Need to connect (D5 pump w/aquabus & usb) and (Aqua Computer Flow Sensor 'High Flow' G1/4 for Aquaero 4/5/6)
mardi 11 mars 2014, 01:58
I need to connect the D5 and the flow sensor to the aquabus "high" but I only have the cables that came with the Aquaero 6, D5 and the high flow sensor cable.
#93111 x2
#53027 x1
How can I connect both the D5 and the flow sensor to the high connection?
Do I somehow have to splice those three cables together to make a Y cable?
Appreciate any help or advice anybody can provide.
Jakusonfire
mardi 11 mars 2014, 13:53
If you have this flow sensor, http://shop.aquacomputer.de/product_info…roducts_id=2294
that uses the flow cable 53027 then it just connects to the flow port on the Aquaero, not the Aquabus.
The D5 connects to the Aquabus high port.
If you have other MPS devices then you can use a 4 pin splitter cable or just solder the cables together.
Ryanboost
mardi 11 mars 2014, 17:53
That's what I have so I'll connect it to the flow port on the Aquaero. Thanks so much for the help.
Discussions similaires
