• 10.10.2026, 11:17
madcratebuilder
Aqua Suite/Aquaero/Tempature sensors
jeudi 13 mars 2014, 00:19
Beside the 2 pin temp sensors you can attach I have 4 listings, "Fan amplifier1 thru 4" and "aquaero CPU". Are these temp sensors on the AQ6? The AQ6 processor and the 4 fan plugs? The AQ6 cpu reports around 38C but does nor feel that warm.
bcikota
jeudi 13 mars 2014, 10:27
Hey madcratebuilder,
Yup, those are the temperatures of the Aquaero components. Amplifier temperature is the interesting one, because, depending on the load and type of cooling it may reach a point where the Aquaero goes into protection mode to reduce the temperature. On Aquaero 5 it speeds up all the fans on the channel to 100% (less load) and on Aquaero 6 I think it switches off the channel temporarily, but I am not sure.
CPU temperature is informative I guess... I have never seen it do something strange.
Kind regards,
Boris.
madcratebuilder
jeudi 13 mars 2014, 13:58
Thanks Boris.
My fan amp temps are always near ambient, aq cpu always near 35C.
Another question, the usb address assignment in the aq manual uses 50-54 as examples. Should I use a address in the 50's? I set up using 12 and 13 for the two D5's.
Cheers
mcb
ETA: I went in to setup and attempted to change usb addresses, I only have a choice of 12-15 so I guess I won't worry about it ;(
Ce message a été modifié 1 fois. Dernière modification effectuée par "madcratebuilder" (13 mars 2014, 15:26)
bcikota
vendredi 14 mars 2014, 00:03
Yup, the address ranges are fixed. MPS devices can be assigned the 12-15 range as you discovered. Aquabus devices such as Poweradjusts can be assigned addresses in a 50-57 range.
You're good to go with your pumps at 12 & 13.
Kind regards,
Boris.
