• 22.11.2026, 23:09
andyman
Spare parts
jeudi 3 avril 2014, 18:36
Hi there... Just got 2 x Kryographics GTX 780 ti waterblocks... One went on fine, but the other... not so much....2 of the screw fittings on the block have broken. I managed to unscrew one of them, the other is stuck in the block. I may be able to drill out the one that's stuck in the block if I have to....... My question is.. is this a common issue? can I get the whole block replaced? or can you send me some replacement fittings?
bcikota
jeudi 3 avril 2014, 19:35
Hi andyman,
I don't have any experience with those waterblocks, but I think you'll have better luck finding a solution if you e-mail Aquacomputer directly (support@aqua-computer.de).
Kind regards,
Boris.
andyman
jeudi 3 avril 2014, 19:47
Many thanks... I'll give that a go... Cheers
Discussions similaires
