• 15.11.2026, 15:11
novax1
RE: Aquasuite and WMI support
mardi 15 avril 2014, 12:04
Hello
I'm trying to export data from HWiNFO64 AquaSuite 2014 -1.3
The problem when you export data are not updated.
To export LCDhype use has created a plugin to export XML
AquaSuite data perfectly updated.
But when I want to export data from hwinfo be updated, only works if I can enable or disable some options AquaSuite 2014
show image
( second image ) so that data is actualizen i work, I show an image, and disable active in Hfinfo64 then works
novax1 a envoyé les images :
Ce message a été modifié 1 fois. Dernière modification effectuée par "novax1" (15 avril 2014, 12:29)
novax1
RE: RE: Aquasuite and WMI support
dimanche 20 avril 2014, 11:07
:love:
