• 18.11.2026, 16:11
santiagodraco
Aquasuite fails to load with "Visual C++ 2010 redistributable package not found"
jeudi 22 mai 2014, 01:39
I've installed/reinstalled Aquasuite 2014 over and over with no success. I've also reinstalled the Visual C++ package.
Running Windows 8.1 64 bit.
Thanks!
santiagodraco
mardi 27 mai 2014, 17:33
Well so much for getting any support from AC here. Not surprising I guess. This is where you find out if people stand behind their products or not.
Rostiger
mercredi 28 mai 2014, 06:04
is microsoft netframework 4 on your pc install ?
without will not work aquasuite, download from microsoft web...
mercredi 28 mai 2014, 07:05
you need this:
http://www.microsoft.com/en-US/download/…s.aspx?id=17718
and this for x64:
http://www.microsoft.com/en-US/download/…s.aspx?id=14632
an x86:
http://www.microsoft.com/en-US/download/details.aspx?id=5555
When the aquasuite is not running with this installed packages something is wrong with your windows installation.
Pocalypse
dimanche 6 juillet 2014, 20:47
I am having the same issue.
.NET framework 4.5 is installed. Trying to install from the link you gave says I have a newer version installed.
Visual C++ redistributable package is installed (both x86/x64).
I'm running Windows 8.1 64 bit, have an Aquaero 6 Pro connected.
I've reinstalled aquasuite & visual c++ many times to no effect. I've restarted my computer.
Please help.
Edit: After installing some games from Steam (specifically assasins creed 4) which also needed the c++ redistrbutable, steam installed it again, and after that aquasuite is running fine. Weird solution, but whatever works.
Ce message a été modifié 2 fois. Dernière modification effectuée par "Pocalypse" (7 juillet 2014, 00:04)
Costas
dimanche 13 juillet 2014, 14:12
I can confirm what Pocalypse has experienced.
I just built a new PC with Win8.1 and received the same error "Visual C++ 2010 redistributable package not found"
After ensuring that Visual C++ 2010 was installed (both 64 and 32 bit versions) I tried installing .NET v4 however Win8.1 will not allow you to install the redistributable package as it has already installed a higher version and it prevents you from loading v4 Redist.
Note that my build is quite sparse in that only Win8.1 and drivers etc have been installed - not much other software.
I think Aquasuite suite is looking for some other/extra files it thinks should be part of the visual C++ redist package but are not there which is preventing it from running.
Costas
dimanche 13 juillet 2014, 14:49
Just an update on the issue as I have just resolved the problem in the last few minutes after my post above.... :thumbsup:
Looks like users must also install Service Pack 1 updates to the Visual C++ 2010 redist package.
Install both x32 and x64 Service packs and you should be good to go.........!
The Service Pack 1 updates may be found here: http://www.microsoft.com/en-us/download/…s.aspx?id=26999
