• 11.10.2026, 04:27
RomSzas
Problem with Aquaero 5 LT after flashing firmware - seems to be dead
samedi 5 juillet 2014, 18:45
Hello!
I got problem with Aquaero 5 LT after flashing the firmware. Aqasuite 2014 ver 2.3 doesn't recognize/show Aquaero.
Aquaero 5 LT I got for few days. I played efficiently in setting the fan - it worked fine, but I wanted to do the upgrade firmware. Originally soft and well functioning was in the 1036 version if I remember correctly.
The update done by Aquasuite - unfortunately the update aquaero 5 LT is not detected by Aquasuite 2014 2.3 - which previously worked. During the update aquaero 5 LT was hooked original USB cable to the computer and plugged him were two fans on one channel, and of course power cable - MOLEX connector.
It seemed that the procedure for changing the software was successfully. Device was restarted and appeared sound beep (as I remember).
When updating says there was something about the possibility of several aquaero in the system - not quite understand - maybe my Aquaero after updating the firmware wants to act as a slave, second?
Aquaero seems to be dead. Fans work with maximum speed.
Is possible to somehow get back to running the working 1036 version firmware?
I would be grateful for help or directed at the solution.
johnnybra
dimanche 6 juillet 2014, 23:12
I think that 1036 is the latest firm for aquaero 5 LT. Are you sure that you don't flash your aquaero as expansion device? If you do that you must put it in recovery mode to use it as standalone one
lundi 7 juillet 2014, 08:21
Use the recoverey mode and flash the firmware again. Download the manual and follow the instructions.
Namron
lundi 7 juillet 2014, 08:33
Download English Manual from HERE (it'll open to Adobe Acrobat reader, I'd advise printing it out for future reference :) ) & go to page 46 where it explains how to do a hard re-set (recovery mode).
N.
RomSzas
lundi 7 juillet 2014, 15:12
Thanks for the link and the solution. Aquaero back to life. Problem solved :thumbsup:
