• 15.11.2026, 16:25
fede3d
i need help with aquaero 6xt
mercredi 9 juillet 2014, 21:23
Hi all guys.
I need to connect 2 flow sensors and 2 pumps (LAING D5) to my aquaero 6 xt.
How should I do that?
Is a single aquaero 6 xt controller enough or should I need some other module?
Last question:
Is there a way to automatically adjust the fan speed and the pump power
depending on the temperatures that the sensors read?
Thanks in advance, bye!
Ce message a été modifié 1 fois. Dernière modification effectuée par "fede3d" (9 juillet 2014, 21:26)
jeudi 10 juillet 2014, 07:13
The 2 flow sensors are not the problem. You can connect the sensors to "Flow and Fan1" connectors.
But your pump is not compatible with the aquaero.
Read this:
Help with Aquaero 6 XT PWM controller.
fede3d
pumps
jeudi 10 juillet 2014, 12:15
OK. please, could you tell me which pumps are compatible?
ty
jeudi 10 juillet 2014, 13:18
The normal D5 without PWM.
Discussions similaires
