• 02.10.2026, 19:32
donohue100
aqua-suite not using minimum speed setting
mardi 2 septembre 2014, 16:59
I have minimum speed set to 3000 rmp 50hz and maximum at 5000 rmp and 84 hz it is in automatic mode, why does the pump not sit at 3000 and always goes to the max speed?
mardi 2 septembre 2014, 17:36
Look at the parameters that you set to control the pump speed, It may be that the max speed condition is in effect.
Under what monitoring condition is the pump supposed to be at 3000/50Hz... that condition may be exceeded.
donohue100
mardi 2 septembre 2014, 18:41
i do not have any settings available to set conditions for pump speed based on any parameter. Where would this be in the software?
mardi 2 septembre 2014, 20:07
I have an Aquaducr 360 XT Mark V and it comes with an Aquaero 6 XT,
Under the pump setting I have a choice of automatic or manual (also deaerate, but that's a special setting). If I select manual then the pump runs at the settings I enter, if select automatic it runs at some predetermined criteria I have no control over.
Given you have a minimum and maximum setting available, there must be a process for the system to decide which rpm to run at between your limits.
Where are you setting the min/max criteria?
Ce message a été modifié 2 fois. Dernière modification effectuée par "InfoSeeker" (2 septembre 2014, 21:18)
donohue100
mercredi 3 septembre 2014, 18:38
mercredi 3 septembre 2014, 22:21
That is different than the Aquasuite display on an Aquaduct XT Mark V.
Your pump appears to be running at 4702 RPM in that screen shot, which is within the min/max parameters you have specified.
But I am not sure what criteria is used to set the pump speed... normally I would suspect water flow or pressure, but as I do not know, I must bow out.
You will probably get your best answer by sending an email to nfo@aqua-computer.de.
They are pretty good about answering their email.
jeudi 4 septembre 2014, 07:09
When your pump is running in auto mode, the pump try to run between the minimum and maximum rmp. In auto mode the pump try to find the maximum possible rpm to run stable.
Wen you need a specific pump speed you have to set your pump in manual mode.
The lowest possible speed is 3000 rpm.
donohue100
thanks
jeudi 4 septembre 2014, 23:02
thanks both of you
