• 23.11.2026, 00:01
Bytales
Aquaero Waterblock Question
samedi 11 octobre 2014, 12:05
I have a question. Im going to aquire an aquaero 6 XT. WIth the red passive heatsink.
I wanted to get also the copper watercooling block.
The one here :
Product number 53093
However on description it says
Please note: aquaero 5 is not included in delivery! The block is not compatible to the aquaero 6!
Not compatible to aquaero 6.
Yet here :
I see a picture with the block attached to the red heatsink, therefore i understand it is indeed compatible.
SO is it compatible or not ?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Bytales" (11 octobre 2014, 12:25)
samedi 11 octobre 2014, 12:20
It means that you can not mount the water block directly to the aquaero 6 but you can mount it to the passive heatsink of the aquaero 6.
Bytales
samedi 11 octobre 2014, 12:26
Thanks for the info, the threads of the waterblock are awfull close to each other, is it possible to use standard g1/4 fittings with those, or do i need something else ?
samedi 11 octobre 2014, 12:44
I found this article a while back... among other things it discusses the waterblock and may answer some questions for you regarding the proximity of the ports.
Scroll down to "FITTING WATER BLOCK"
Though if you read Shoggy's introductory post for the New:Aquaero 6, a waterblock may be unnecessary. Just go with the passive heatsink, that is what I plan to do.
Ce message a été modifié 5 fois. Dernière modification effectuée par "InfoSeeker" (11 octobre 2014, 13:08)
bcikota
samedi 11 octobre 2014, 19:03
I had to use one extender to be able to fit EKWB compression fittings on the water block.
Kind regards,
Boris.
Bytales
samedi 11 octobre 2014, 19:51
I think two of these will fit perfectly.
http://shop.aquacomputer.de/product_info…roducts_id=2322
Someone correct me if i"m wrong !
lundi 13 octobre 2014, 09:44
They work.
Discussions similaires
