• 22.11.2026, 23:53
Bytales
RGB Diodes in Aquaaero 6 XT
samedi 11 octobre 2014, 18:42
After reading in the manual it says like this:
Connector „RGB LED“
Connector for up to three LEDs or one two-color or RGB illumination module
(not included in delivery).
Using a RGB Module like the one here , inside a plug like this one , that goes inside a reservoir on the bottom (could that be used inside this reservoir here (thats made from 3 different pieces) ?, if not, which reservoirs compatible with this combination ?) one could control the led based on water temperature, or delta, (if two sensor are within the same loop at different points) to make it different colors.
The question is, if one can connect more that 1 RGB illumination modules, meaning 2, to the aquaaero 6 XT, or do i need to get something extra ?
lundi 13 octobre 2014, 09:43
You can only use one RGB LED wiht the aquaero. Two or more LEDs would overload the output and could damage the electronic.
The mentioned transparent plug can be used to install the LED to the reservoir.
Bytales
lundi 13 octobre 2014, 10:34
Thanks for all the answers Shoggy, here, and in my other Threads.
Now, how could i use 2 of these RGB Leds, if the aquaero 6 can drive only one ?
Through eny other equipement you may offer, ?
Or am i stuck with only one ?
lundi 13 octobre 2014, 11:48
We do not offer anything that will work with two ... yet ;)
Bytales
lundi 13 octobre 2014, 14:01
Now theres something thats going to need to get upgraded ! At least now i know !
wa3pnt
lundi 13 octobre 2014, 20:25
This is what I use with the Aquaero 6XT to drive about 8 feet of RGB Strip lighting.
Works GREAT!
Jeak RGB Amp
RodeoGeorge
mcrustk2
samedi 14 août 2021, 19:49
Hi @Shoggy, has this changed? I have an Aquaro 6LT and two illumination modules I would like to use to illuminate two of your filters, is there anything I can use to make this work?
Thanks,
Ce message a été modifié 1 fois. Dernière modification effectuée par "mcrustk2" (18 août 2021, 18:37)
