• 29.11.2026, 07:39
Blefbek
Aquaero 6 pro relay.
dimanche 9 novembre 2014, 16:27
It about a week or three ago when i did build in the aquaero 6 pro. So for now i am gonna use the relay within the atx power break connector.
So i did purchased one, but when i installed the connector i can´t see the function nearly into the firmware itsefs from the device under outputs. I did flashed the firmware but it gives me no relay feature .
I wanne have the relay function because of an new win 7 boot when i must takeoff the connector from the mainboard after a proper shutdowm whitin a watertemp signal. I know the 5 pro do have the relay function directly into the firmwar so an reset is into the device the manner.
Do you guys know this issue?
lundi 10 novembre 2014, 11:21
Make sure that the extended green wire of the adapter is cut and the ends are connected to pin 1 and 3 of the relay plug.
The rest only depends on your alarm configuration. Here is a simple example for a shutdown based on a temperature alarm:
Blefbek
mardi 11 novembre 2014, 17:57
solved, only it is a pity that I can not find it in the firmware
vendredi 14 novembre 2014, 16:06
It can be also configured directly with the device.
Main menu -> Alarms -> Alarm and warning levels -> Alarm (for example) -> 1st action to be performed and so on.
Pretty much the same way to setup the alarm limits.
