• 10.10.2026, 19:21
Amuro
Screw question for mounting 170-180mm fan on a Gigant radiator
mercredi 10 décembre 2014, 16:45
Does anyone what size of screws is used on the fan as shown in the following picture?
mercredi 10 décembre 2014, 22:05
It depends on the fan you install.
I am installing two T.B.APOLLISH UCTA18A fans which are 20mm deep, so I got M4 x 30mm for the top fan and m4 x 35mm for the bottom fan. The top fan screws requires nuts, and the bottom fan screws screw into a tapped holes in the radiator bottom.
Amuro
jeudi 11 décembre 2014, 04:56
So M4 will fit through the slots on the top cover?
I have a Phobya 180mm x 32mm G-Silent 18.
Edit
I measured the width of the slot, which is 3mm so I guess M3 screws?
Ce message a été modifié 2 fois. Dernière modification effectuée par "Amuro" (11 décembre 2014, 07:58)
jeudi 11 décembre 2014, 17:02
Oops, my bad, M3 indeed... phat phinger typo.
dimanche 1 février 2015, 13:09
Just wanted to update & correct my reply.
The slot size in the top cover/mounting bracket are 3mm wide (m3), but the mounting holes on the bottom are for m4.
