• 14.11.2026, 04:11
Cenedd
Aqualis XT fill sensor Aquabus vs USB
jeudi 11 décembre 2014, 21:14
I've got an Aqualis XT reservoir installed and now that I've changed the Aquabus ID (also have an MPS flow sensor on a Y-cable), it's picked up by Aquasuite over the 4-pin high-speed Aquabus. The problem is that it is seen as a pressure sensor reading 0.0bar. If I plug it in by USB I can change it to a level sensor and calibrate it but when I then disconnect the USB and return to Aquabus, it only shows as a pressure sensor again. Am I missing something or is it a requirement to have it connected by USB?
Many thanks,
Gareth
dimanche 14 décembre 2014, 13:10
Which version of aquasuite are you using?
Cenedd
dimanche 14 décembre 2014, 19:12
The latest 2015 version. It updated the Aquaero 6 XT firmware to version 2000.
Discussions similaires
