• 10.10.2026, 03:04
Goudman
Aquasuite 2015 - Not Detecting Aquastream XT Ultra Pumps
lundi 19 janvier 2015, 11:07
Having an issue with the Aquasuite 2015 showing either of the two Aquastream Pumps I have (in series) in my system.
Here is my process:
1. Aquasuite 2015 Loaded, OK looks great
2. connected Power adjusts, farbwerk and Tubemeter per AC recommendations, OK, everything works great.
3. Connect Aquastream Pump 1; Does not appear in Aquasuite main menu, Connected Pump 2, does not appear either in Aquasuite
(I connected the Pump with the USB connection only (I did not connect the Power supply through molex connection at the same time)) when I first booted the pump.)
4. I tried this process several times, no luck. Also connected Aquabus with USB and still not showing in Aquasuite menu.
I am looking for advise; Should I purchase the Aquacomputer aquastream XT Firmware-Flasher for Parallel Port and flash each pump, then try again? ?(
I need a step by step process to eliminate potential issues so I can troubleshoot why the pumps are not talking to the Aquaero 6 XT. :thumbup:
Please advise. Shoggy or Sebastian, your help will be fantastic as well. These are the final AC cooling components to perform pre-setup testing before I place them into the case permanently.
Thank You
lundi 19 janvier 2015, 11:46
The Pump is not Powered by USB or aquabus. The Pump needs to run the 12V connection.
Goudman
lundi 19 janvier 2015, 20:48
Sebastian,
I was of the understanding that the Molex connector did not have to be connected to set-up the pump in the Aquasuite.
So my assumption of using the only the USB connector for set-up in the Aquasuite was incorrect? Please confirm.
lundi 19 janvier 2015, 21:02
You need the POWER Connection.
The pump is not powered from USB or aquabus. Read the manual.
Goudman
mardi 20 janvier 2015, 11:04
Sebastian,
Issue solved
Thank You
