• 03.10.2026, 15:12
Wredny
Aquaero 5 LT - temperatures at low voltage
mercredi 21 janvier 2015, 21:11
Hiya all, i have small trouble... my Aquaero 5 LT hits 90+ C with 4xCorsair SP120 LED plugged in (in one 3pin port) on voltage 5-7V... at 12V temperatures are around 45. The funniest part is that on 4xCorsair SP120 nonLED plugged the same way, on every voltage (5,7,12V) temperatures are great...
nonLED fans have 0.09A (12V), LED have 0,26A at 12V. This mean i have to buy waterblock for it..?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Wredny" (21 janvier 2015, 21:15)
pcRelic
jeudi 22 janvier 2015, 10:55
Waterblock, or maybe this should be enough: Heat sink for aquaero 5
Jakusonfire
vendredi 23 janvier 2015, 07:09
The more power the fans that are connected use, the more power the aq5 has to get rid of at lower voltages. That creates more heat.
The heat sink should be enough to bring temps under control unless you plan to use many more of the led fans.
Discussions similaires
