• 10.11.2026, 09:33
Railgun
Yet another feature request-increase SW temp sensor limit
mardi 24 février 2015, 10:43
As I understand, there's a limit of eight software temperature sensors that can be used within aquasuite. Not specifically eight within one aqua computer, but eight within the software as a whole.
I'm using two AC6 XTs, and I want to use some of the software sensors used in one to control fans in another.
However due to the limitation of only eight, the software sensors already used in the first AC stop functioning in favor of being used in second, which screws up my already existing fan curves.
That being said, can a tweak be done within the software to remove this limitation. If not, what is the cause of this limitation?
Thanks in advance.
Railgun
samedi 28 février 2015, 11:55
Sebastian...Shoggy...
So is this a HW or SW issue and can it be fixed?
samedi 28 février 2015, 11:58
In the next release this bug is fixed.
You can use 8 indiviual sensors per device.
Railgun
samedi 28 février 2015, 13:33
Awesome!
Thanks.
