• 26.11.2026, 00:04
mardi 3 mars 2015, 08:39
You need resistors like the "These LEDs also come with our free wiring guide to help you get started immediately.". Without resistors you damage your LEDs and the farbwerk.
The source voltage from farbwerk is 12V.
Railgun
mardi 3 mars 2015, 08:40
Those aren't 12v LEDs. It says it right on the page.
Provided the correct voltage, LEDs in this respect don't care about amperage. They will draw whatever they draw. if amperage provided is less that what the LED can use, it will be dimmer, that's all. If the strips require more than the 2.5A the farbwerk can provide, you kill the unit.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Railgun" (3 mars 2015, 08:42)
jmonteiro
mardi 3 mars 2015, 15:08
If you look at the eBay page (where I bought them from), they do say:
  • Recommended resistance: 330 to 1K Ohms with 5.0V to 12.0V operating voltage
I guess I need to buy some resistances.
Thanks,
Jorge[list][*][/list]
Railgun
jeudi 5 mars 2015, 20:06
I'd like to expand on Jose's feedback post.
More of a possible bug in this instance.
I too would like some of the features with regards to what the farbwerk itself can do brought down to the auqaero. Instead of having to tell the farbwerk to either have absolute control or pass it off, if passing, it seems as though it's simply a SW issue to get that functionality in there.
Secondly, and this may be a bug of sorts, and not that much of an issue for me, but when rotating colors at full speed via aquaero control, the color gradients are not smooth. The LEDs are stepping through the colors. Slowing it down smooths things and the transitions are much nicer. The slower it goes, the smoother it is. Can this be a limitation to how much data is being sent from the auqaero to the farbwerk via auqabus, or at least the speed of data (assume it's simply a serial protocol of some sort)? Though, I didn't notice any difference if controlling all four outputs as opposed to one. The effect seemed to be the same. When rapidly cycling through the spectrum via native farbwerk control at full tilt, it's very smooth.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Railgun" (5 mars 2015, 20:07)
Jenko97
jeudi 12 mars 2015, 21:54
I've recently installed a farbwerk into my system and have been using my phobya rgb led strips and it has worked great.
However, I've decided to buy the aquacomputer strips as they are longer and better suit my needs. I didn't realise at the time that the cables weren't included and am struggling to connect them as I have no wire.
Is this the only way to connect them: http://shop.aquacomputer.de/product_info…roducts_id=3231? I can't seem to find this cable anywhere in the UK except overclockers which are out of stock at the moment. http://www.overclockers.co.uk/showproduc…428&subcat=1430.
Are there any generic connectors I can buy on amazon to connect the strips? I would ideally like to avoid paying to ship three cables from Germany to Ireland when I can get them somewhere more locally.
Thanks in advance for any feedback.
Railgun
vendredi 13 mars 2015, 08:52
Ce message a été modifié 1 fois. Dernière modification effectuée par "Railgun" (13 mars 2015, 08:55)
Jenko97
vendredi 13 mars 2015, 12:13
Thanks for the response I appreciate it :thumbsup:
However I already have similar cables to this and there is no way of connecting that connector to the aquacomputer led strips. They work with the phobya strips and that 4 pin connector is what goes into the farbwerk but the end of the aquacomputer strips have seemingly no plug in which to connect the cable to the farbwerk. I think that the aquacomputer strips require a specific cable and I am struggling to find the right cable near the uk.
If I'm not mistaken, this is the correct cable:
I have a feeling that this is another generic connection that I can get somewhere locally.
I don't mean to be rude, I really do appreciate your help but I don't think this is the right cable. :D
vendredi 13 mars 2015, 12:35
You have probably checked this out, but in case, Aquatuning UK has 2 weeks delivery for the patient. :)
Jenko97
vendredi 13 mars 2015, 12:42
Thanks, don't fancy that 2 week delivery but it looks like it could be the only option. Either that or wait until overclockers have it in stock. :(
Railgun
vendredi 13 mars 2015, 13:53
No worries. I've not seen the AC strip in person, so I assumed it would be the same connector as the farbwerk provides. How silly of me to think they were the same... ;)
XenoMorpH
jeudi 26 mars 2015, 07:13
I just received my farbwerk. Connected it trough aquabus and USB.
My 5LT sees the farbwerk on Bus address 20. The device also appears in the device list. I can also adjust the color settings withint the device itself using USB, but how can I control the device with the aquabus with no usb connected?
jeudi 26 mars 2015, 14:05
I do not have a farbwerk nor the 5LT, but I believe under the 5LT tab, you select the "Controllers" Tab, click on the "+" symbol next to "Outputs" (upper right) & select "LED controller", and set it up there.
XenoMorpH
jeudi 26 mars 2015, 16:27
I did, but it does not work. I had 2 ledstrings attached to the controller, I could only select 1; Farbwerk(1) 1-R /G/B. But I was not able to control the colors either. What am I doing wrong here ;(
jeudi 26 mars 2015, 16:34
In the farbwerk setup you have to configure the farbwerks outputs as external controlled.
XenoMorpH
jeudi 26 mars 2015, 18:21
8| Is there any documentation on how to do so? I have no idea how to solve this (maybe I should make a different thread and not to hijack this 1).
EDIT:
Added the output and added the controller.....still not working.
Ce message a été modifié 1 fois. Dernière modification effectuée par "XenoMorpH" (26 mars 2015, 20:29)
Railgun
jeudi 26 mars 2015, 21:11
Deselect switched output.
vendredi 27 mars 2015, 07:12
You have to set the output mode in the farbwerk to external.
XenoMorpH
vendredi 27 mars 2015, 15:40
:thumbsup: ...I completely overlooked that optinion :pinch: 8| All fixed now, tnx!!
Blade Runner
mardi 31 mars 2015, 10:16
Can you connect RGB LED single bulbs to the Farbwerk or only LED Strips?
Beercules
vendredi 29 mai 2015, 00:05
what is the second aquabus connection used for?
Thanks,
Beercules
