• 26.11.2026, 11:33
Marucins
Tube, clamp and cap for Koolance COV-RP450
jeudi 30 avril 2015, 12:00
I have a top for pump D5 - Koolance PMP-450/S, Rev.2.1
http://koolance.com/pump-nozzle-and-rese…pmp-450-60mm-od
I'm going to buy the tube - 60x200mm or 80x200mm
http://koolance.com/reservoir-body-60-x-200mm-393ml
http://koolance.com/reservoir-body-80-x-200mm-770ml
I want to mount the tube on top of the pump. I need a clamp and cap at the Top of at least two holes.
I'm thinking of such a thing:
http://shop.aquacomputer.de/product_info…roducts_id=2918
http://shop.aquacomputer.de/product_info…roducts_id=2956
Will it fit?
If so, to which 60 or 80?
jeudi 30 avril 2015, 17:13
The clamp you linked is made for aquacomputer aqualis reservoirs which have an outer diameter of 75 mm.
Neither the 60mm or 80 mm tubes you linked will fit exactly... can you make it work? Perhaps.
The cap you linked is also made for an aquacomputer aqualis reservoirs and is a different diameter (75 vs 60/80). The cap also does not secure to the top of the tube by threading onto the tube, instead aqualis uses an inner stainless steel tube to secure the top to bottom, with a pressure fit to the reservoir tube.
If you wish a multiport top, it may be easiest to use the aquacomputer D5 pump top which direct connects to a aqualis reservoirs, which will fit the tube clamp and the multiport tube cap you specified, as one single. integrated unit.
Edit: If you decide to go with the aqualis reservoir, there are variations in size/capacity as well as upgrades. Just search for aqualis base in their shop and you should get a comprehensive list.
Ce message a été modifié 4 fois. Dernière modification effectuée par "InfoSeeker" (30 avril 2015, 20:21)
Marucins
jeudi 7 mai 2015, 21:17
Ce message a été modifié 1 fois. Dernière modification effectuée par "Marucins" (7 mai 2015, 21:30)
jeudi 7 mai 2015, 21:37
Please contact the other companies for further support.
Our forum is no support forum for products of competitors.
jeudi 7 mai 2015, 22:37
Indeed, but to be fair, his original post was looking for information on aquacomputer gear compatibility with some equipment he had.
And then I asked him for a status follow-up in his D5 pump connection thread.
So, my bad... sorry.
Discussions similaires
