• 13.10.2026, 14:38
JasonMorris
Just opened my Farbwerk and 53188 500cm RGB-LED strip
lundi 4 mai 2015, 14:06
And after removing the 3m backing the strip is not sticky at all. Can't fix it to my chassis?
Is the a common issue or have I got a dud roll?
Thanks.
Railgun
lundi 4 mai 2015, 19:47
Every LED strip I've ever had has crappy tape. I picked up some thick double sided tape. It's almost like a tar tape, but not as tough. I'd suggest that.
JasonMorris
lundi 4 mai 2015, 20:30
Thanks for the reply and I'll try and grab some.
mandrix
mardi 5 mai 2015, 15:28
I like the 3M brand rolls of tape sold at hardware or big box stores like Lowes. It's about 1/2" or 12/13mm wide. Works good for most led strips I've used. In extreme situations the heavy duty 3M double sided sticky like railgun said is boss.
