• 29.09.2026, 15:22
Data Log question
jeudi 14 mai 2015, 00:48
Well, this is embarrassing, but I need help find the entry point to create a Data Log. The manual states:
10.1. Log settings
The log settings can be accessed by clicking the “Log settings” element below
the “Data log” headline in the listing.
But the only "Data Log" I see is a tab under the aquaero in aquasuite, and it does not accurately reflect the options discussed in the manual.
Railgun
jeudi 14 mai 2015, 11:27
You don't have this section in Aquasuite? It should be there and I'm not aware of any way to remove it, or add it if not there.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Railgun" (14 mai 2015, 11:29)
Jakusonfire
jeudi 14 mai 2015, 12:30
First go to log Settings and add some data sources that you want to use.
Add the Data Sources to a chart
Save the chart for use in an overview page
Ce message a été modifié 1 fois. Dernière modification effectuée par "Jakusonfire" (14 mai 2015, 12:32)
jeudi 14 mai 2015, 20:17
Wow, talk about Major Brain Fart... I got locked on the Data Log tab under the aquaero and didn't see the primary one I needed. I'll ask later what the aquaero Data Log is used for.
OK, I set up a data set, made the chart the way I wanted, saved the chart and am able to pick it up on the Display Page.
Only thing is, when I closed the edit function of the display page to set it on the desktop, the data log graph is not there.
I know it must be something simple, but am not able to determine my error.
Edit, by the by, thank you both very much for your help.
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (14 mai 2015, 20:19)
samedi 16 mai 2015, 15:13
Well, I re-installed aquasuite as repair, and that did not fix the issue, but a re-install as new did.
samedi 16 mai 2015, 23:06
OK, moving on... I am trying to have the Data Log display show 15 minutes of data to match the rest of the elements, but am able to show only a 30 minute window. Is this the only Time Frame available?
I set the Time Frame to 15m in the Data Sources tab of the Chart Configuration section to no avail.
dimanche 17 mai 2015, 04:05
mhmm, it appears one has to set the Time Range prior to adding the data to the chart... looks like it is not changeable once the chart is started.
Discussions similaires
