• 30.09.2026, 04:14
cincilleo
ATX break problem
dimanche 26 juillet 2015, 15:10
Hi all
I'm setting up new configuration with aquaero 5 pro and i have bought an atx break
I have power on aquaero even with the pc turned off and it's ok
I have connected the two n.16 pin (green) to relay port in aquaero.
If i set an alarm with the event realy on the pc turn off for a couple of seconds, then power up again
Now the question is: is possible that pc remain POWER OFF after an alarm? I'm doing something wrong?
Thank you
cincilleo
lundi 27 juillet 2015, 12:41
no one has the knowledge to reply?
mandrix
lundi 27 juillet 2015, 12:51
Do you have the wiring from pin 16 to the motherboard split at the relay? You must make sure there is not another path for current to travel from the psu to the motherboard.
Without looking directly at yours I don't know what else to tell you.
If you are positive you have it wired correctly, maybe some setting in your BIOS is causing it to restart.
Anyway, I have my Aquaero relay wired directly across the case switch, which to me is the easiest way on my rig. I was going to use the ATX break but this way just seemed simpler to me.
cincilleo
lundi 27 juillet 2015, 14:45
Yes the aquaero is across the two greens... but when the relay switch on the computer power off the the aquaero turn the relay on and the pc restarts...
So you think is better to connect the aquaero between the power switch? can you send a me photo of your configuration?
Thank u
mandrix
lundi 27 juillet 2015, 17:00
I don't know if the way I did it is better for you. Either way will work.
The forum isn't letting me post a pic from my pc, but basically you just wire the relay across the power and ground...you can do this at the switch or you can do it at the motherboard front panel pins.
cincilleo
mardi 28 juillet 2015, 01:43
what colors and pins are the power switch on the 24 connector?
mardi 28 juillet 2015, 15:34
ATX Pinout
cincilleo
mercredi 29 juillet 2015, 14:46
mmm if i short green wire and ground the pc doesn't power on/off...
where is the mistake?
Discussions similaires
