• 17.11.2026, 14:58
Kinsy
AQ6 and ATX Break
mardi 11 août 2015, 10:53
I have an Aquaaero 6 and I want to use the relay to do an ATX break.
On the 5 you just plug the cable into the port marked STANDBY.
With the 6 the RELAY socket requires a plug (which I have) but it's not clear what cables need to be connected to it.
I have the ATX Break cable as well, I just need to know what to cut and wire in to the RELAY plug.
mardi 11 août 2015, 11:38
You have to cut the green wire of the ATX break adapter and connect the end to pin 1+3.
The standby power is not used anymore for the aquaero 6.
Kinsy
mercredi 12 août 2015, 22:49
Perfect thank you!
