• 18.11.2026, 08:43
Drake
Temperature sensor product n° 53067 spare part?
samedi 5 septembre 2015, 10:19
Hi all.
I've lost the enclosure fitting for the temperature sensor product n° 53067.
Is possible to buy it or i have to replace the whole sensor?
Thanks!
RE: Temperature sensor product n° 53067 spare part?
dimanche 6 septembre 2015, 00:23
Hi all.
[attach]5371[/attach]
Thanks!
I believe that sensor is not meant to be taken apart, so you are probably best served replacing it.
And a spare part will probably cost near what the complete item does. :)
dimanche 6 septembre 2015, 21:34
You can get almost everything as spare part through the e-mail support. But like InfoSeeker said, II also think getting a new sensor will make more sense in this case.
